[TESTING] Kodi 18 (Leia) builds for Vero 2 & 4K
When beta 3 is released
17.8-330, 20 Sept 2018: Based off OSMC commit (5c7028cb4) and xbmc (2c44473e6)
inputstream.adaptive:
  • [DASH] initialize encryptionscheme for tree updates / without representations will be skipped and therefore not updated (8d49b9d)
Includes latest addons:
Includes latest addons: inputstream.adaptive (8d49b9d, +2), inputstream.rtmp (0cc2da1), peripheral.joystick (08e4a1a), peripheral.xarcade (91567dd), pvr.argustv (c57a5c4), pvr.demo (481f2fa), pvr.dvblink (72ef8a0), pvr.dvbviewer(dd9c518, +13), pvr.filmon (93ae10d), pvr.hdhomerun (7a607c9), pvr.hts (8b66ec3), pvr.iptvsimple (e8effad), pvr.mediaportal.tvserver (b17d5ad), pvr.mythtv (22aa23b), pvr.nextpvr (441edde), pvr.njoy (204d95b), pvr.octonet (1e44819), pvr.pctv (9d95bab), pvr.stalker (2eb66d1), pvr.teleboy (0f3ccfd), pvr.vbox (40ca81f), pvr.vdr.vnsi (bb4fb30), pvr.vuplus (07ec214, +9), pvr.wmc (0aea001, +4), pvr.zattoo (8de69a1), vfs.libarchive (f93a5f3), vfs.sftp (e69acc9), pvr.sledovanitv.cz
Any update about this? I just installed latest nightly and the dhd_dpc is still on top.
You can try going to the devel build which has a later version of the kernel.
sudo nano /etc/apt/sources.list
Add:
Save and then run updates
sudo apt-get update
sudo apt-get dist-upgrade
If you don’t want to stay on the devel version then uncomment the line in apt.sources.
17.8-331, 22 Sept 2018: Based off OSMC commit (bf7d7715c7) and xbmc (c6006328)
OSMC:
  • Update to libbluray 1.2.0
XBMC:
  • [bluray] Revert handling still event with pause. (PR:14459, 2 commits, 2 files changed)
  • [darwin] allow macOS SDK 10.14 & iOS SDK 12 (Xcode10) (PR:14457, 2 commits, 3 files changed)
pvr.hts:
  • PVR Addon API 5.10.2: Implemented support for PVR_ADDON_CAPABILITIES. (PR:376, 1 commit, 4 files changed)
Installed the kernel. It didn’t help.
Check the advices in the last 5 posts in this thread
I’ll check it out. Thanks!
Done all the update process, still 17.8-330 here. Am I missing something?
– Added the following lines to /etc/apt/sources.list:
deb Index of /osmc/osmc/download/dev/gmc-18 gmc-18 main
– Run the following commands:
sudo apt-get update
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:4 Index of /debian stretch InRelease
Hit:6 Index of /debian stretch-updates InRelease
Hit:2 Index of /osmc/osmc/download/dev/gmc-18 gmc-18 InRelease
Hit:7 Index of /debian stretch Release
Hit:3 Index of /osmc/osmc/apt stretch InRelease
Hit:5 Index of /osmc/osmc/apt stretch-devel InRelease
Reading package lists… Done
Building dependency tree
Calculating upgrade… Done
udoo apt-get install vero3-mediacenter-osmc
vero3-mediacenter-osmc is already the newest version (17.8-330).
Mirrors most likely not synchronized. Wait an hour and try again
Yeah, just had to wait a little longer, thanks!
I can confirm that UHD Blu-ray folder is working now :+1: :+1:.
I tried unplugging power but it didn’t help. I don’t want to reinstall at this time as this is only minor issue. Hopefully it will be resolved in the future.
It is already resolved. So there will be no fix for it.
17.8-332, 24 Sept 2018: Based off OSMC commit (bad77199) and xbmc (3701f7d8d)
OSMC Skin Alpha 17.9.3-11
  • DSD label hotfix (43ef362)
  • Add DSD music labels (37a5e50)
XBMC:
  • RendererDRMPRIME: set color drm properties (PR:14452, 6 commits, 10 files changed)
pvr.vuplus:
  • Fixes (PR:94, 3 commits, 6 files changed)
17.8-333, 26 Sept 2018: Based off OSMC commit (fe8098635) and xbmc (10b615c7)
XBMC:
  • Revert ā€œVideoPlayer: WinRenderer - add smooth motionā€ (PR:14472, 1 commit, 2 files changed)
  • DVDDemuxFFmpeg: correctly set probeBuffer size matching avioread chunk (PR:14465, 1 commit, 1 file changed)
  • [videoplayer] Fix usage of external vob subtitles. (PR:14471, 1 commit, 2 files changed)
  • [JSON]Fix Player.GetItem during track change seg fault (PR:14454, 1 commit, 2 files changed)
  • [docs/python] Fix docs for xbmcgui Python module (PR:14476, 1 commit, 1 file changed)
  • RPI: Be sure to register Alsa and Pulseaudio. (PR:14453, 1 commit, 2 files changed)
pvr.vuplus:
  • Turned icon fix into an option (PR:95, 1 commit, 7 files changed)
How to force 10 bit mode on Leia?
4k movies plays in 1080p. How to force 4k?
It is a known issue?
Best regards
I figure it out…
I add some resolutions to white list and 4k HDR 10 bit works but not every movie…
All 4k files with 59.940 fps opens in 1080p and 47Hz and green tinted scerrn. Sometimes they open in 1080p and 59Hz. I
When I add 59.940 to whitelist I doesn’t see any picture at all.
This is the only issue I see after one day of testing. Everything else is working ok.
Best regards
This will likely be fixed when Kodi v18 is stable.
Make sure you are also up to date with OSMC packages.
17.8-334, 28 Sept 2018: Based off OSMC commit (f62e80801) and xbmc (9414f105)
XBMC:
  • [docs] Fixed a typo. (PR:14477, 1 commit, 1 file changed)
  • [linux] allow overriding the userdata dir (PR:14460, 2 commits, 2 files changed)
  • Armv7 build neon (PR:14250, 1 commit, 4 files changed)
  • Update game.controller.default to v1.0.7 (PR:14482, 1 commit, 1 file changed)
17.8-335, 30 Sept 2018: Based off OSMC commit (8760fdfc54) and xbmc (1b4f69caea)
OSMC Skin v18 Alpha 17.9.3-12
  • Hotfix Opacity Dim Factor variable (0e699b20)
  • PVR group manager hide option hotfix (0f2e2062)
XBMC:
  • [python] bump for leia (PR:14493, 1 commit, 2 files changed)
  • [docs] Add initializer list whitespace convention in Code Guidelines (PR:14492, 1 commit, 2 files changed)
