I tried in my other TV (different manufacturer) and it also doesn’t save the video calibration.
I confirm the issue on scan for new content in the last two releases, reverting to 345 fixes it and everything runs fine again.
These are obviously test builds and we do appreciate your testing. We’re working hard on resolving these issues.
17.8-348, 12 Nov 2018: Based off OSMC commit (91c8c4d71) and xbmc (c895e84b)
XBMC:
- [PVR] Remove ‘Use simple Timeshift OSD’ setting from settings.xml. (PR:14846, 1 commit, 1 file changed)
- [cmake] Rework FindJsonSchemaBuilder on the model of FindTextureBuilder (PR:14774, 1 commit, 1 file changed)
- Fix screensaver/DPMS interaction (PR:14845, 3 commits, 1 file changed)
- Allow StartPercent property to be 0 (PR:14649, 1 commit, 1 file changed)
- [skin.estouchy] Fix order in Recent Movies (PR:14837, 1 commit, 1 file changed)
- Add missing epoll header (PR:14570, 1 commit, 1 file changed)
- [PVR] New PVR playback setting: ‘Delay mark last watched’. (PR:14836, 2 commits, 7 files changed)
- [PVR] Make ‘Simple Timeshift OSD’ an advanced setting; remove corresponding standard setting. (PR:14840, 1 commit, 6 files changed)
- [filemanager] Fix crash due to multiple busy dialog request. (PR:14839, 1 commit, 2 files changed)
- windowing/gbm: set default plane formats and use the getter methods (PR:14821, 1 commit, 3 files changed)
- windowing/gbm: use the drm render node fd for the vaapi proxy (PR:14820, 3 commits, 9 files changed)
- [cmake] fix building with internal fmt (PR:14830, 1 commit, 1 file changed)
- windowing/gbm: fallback to non-alpha visual id (PR:14785, 3 commits, 7 files changed)
- [Settings] Implement FindIntInList in CSettingList (PR:14815, 1 commit, 3 files changed)
- [GUI] reinitialize addon path after returning with … directory item (PR:14803, 1 commit, 1 file changed)
- [PVR] Performance: Try to fetch missing EPG tag from backend at most every 30 secs. (PR:14806, 1 commit, 2 files changed)
- [GUI] re-evaluate playcount (watched state) when reading from filecache (PR:14810, 1 commit, 1 file changed)
- fixed: do not derefence nullptrs, log using id string (PR:14808, 1 commit, 1 file changed)
- Fix coverty warnings (PR:14798, 1 commit, 2 files changed)
- [cmake] fix building with internal libs (PR:14797, 1 commit, 2 files changed)
- Trigger updateresolution on stream start to set fps in RM properly (PR:14799, 1 commit, 3 files changed)
- [Estuary] Two small fixes (musicvis, videofullscreen) (PR:14800, 2 commits, 2 files changed)
- RetroPlayer: Modernize OpenGL rendering (PR:14522, 5 commits, 9 files changed)
- [skin.estuary] Fix visibilty of overlay icons for wall views (PR:14805, 1 commit, 1 file changed)
- [python-scrapers] extended music artwork (PR:14752, 1 commit, 1 file changed)
- whitelist movie set artwork from scrapers/NFO files (PR:14667, 3 commits, 5 files changed)
- FFmpeg: Bump to 4.0.3-Leia-Beta5 (PR:14782, 1 commit, 4 files changed)
- Fix remote access to images accidentally blocked by Cve 2017 5982 patch (PR:14783, 1 commit, 2 files changed)
- Revert “windowing/gbm: add VT handler” (PR:14776, 1 commit, 5 files changed)
- [GLES] VideoPlayer: more cleanup (PR:14746, 1 commit, 5 files changed)
- [xbmc][settings][GL][DX]: Remove test patterns (PR:14725, 1 commit, 16 files changed)
- Fix include auto-mounted drives remote access allowed check (PR:14758, 1 commit, 1 file changed)
- [addons] remove CAddonDll::GetSetting() is calling the parent only (PR:14753, 1 commit, 2 files changed)
- [skin.estuary] Add 8K support (PR:14760, 1 commit, 2 files changed)
- [depends] bump libdvdcss to 1.4.2-Leia-Beta-5 (PR:14759, 2 commits, 2 files changed)
- [PVR][settings] Get rid of CSettings’ and CSettingConditions’ PVR dependencies. (PR:14763, 1 commit, 11 files changed)
- [PVR] Reduce PVR build dependencies: Get rid of pvr/PVREvent.h (in favour to forward declarations). (PR:14764, 1 commit, 9 files changed)
- [test] Change kodi-test help text to right names (PR:14765, 1 commit, 1 file changed)
- [VideoPlayer] SetResolution synchronously instead RM::TriggerResolution (PR:14755, 1 commit, 1 file changed)
pvr.mythtv:
- fill date of airdate as needed (b00d18d)
- show status of recording (630e0de)
- show status of broadcast (e00e0a0)
- include fr_FR map for eit categories (73b3218)
- bump version 5.8.18 (bd697d5)
- Non zero startTime for recording stream breaks played position (303158e)
- bump version 5.8.19 (0517d4b)
- fix unusable wstring_convert for my platform
(52d22cf) - bump version 5.8.17 (bf90418)
- remove special characters in label of built in recording group (2c0289a)
- rename formattedTitle to groupingTitle (bb446c0)
- update travis.yml (8a94280)
- bump version 5.8.16 (8150695)
- default settings (4cf000a)
- bump version 5.8.15 (db3e73b)
- fix 32 bits time_t (7b6f1cb)
- bump version 5.8.14 (ca6620b)
- update Danish translation (PR:105, 1 commit, 1 file changed)
- handle damaged recordings (a5058f0)
- revert part of commit 66311a6e5479cf739b6598dd502cf73e7a6fa829 (8147f82)
- bump version 5.8.13 (4d07281)
- bump version 5.8.12 (5232720)
pvr.teleboy:
- Reduce logging to LOG_NOTICE (c6c4e53)
- Port GetStringOrEmpty from pvr.zattoo (fbf26cb)
- Update version and changelog (bdbd6b2)
pvr.zattoo:
- modernize & bugfixing (#28) (6188857)
- Fix channels not loading (1831339)
- Update version and changelog (8ddb060)
- Fix segfault strlen (PR:30, 3 commits, 4 files changed)
- Update version and changelog (278d4be)
inputstream.adaptive:
- [WVD] Implement full body encoding (395b7b4)
- [WVD] fix placeholder offsets (0bd5159)
- Version bump 2.3.7 (6cf59e8)
- [MPD] implement base-domain relative paths (5a7d53a)
pvr.dvbviewer:
- Add file flags to StreamReader as suggested by FernetMenta (c2e97a1)
- Move more classes to dvbviewer namespace (f98999f)
- Add support for (on-the-fly) transcoding of recordings (0025954)
- appveyor: run apt-get update (8dd1ddb)
- fix 32 bits time_t (e801485)
- Bump version to 3.7.5 (a9b204e)
peripheral.joystick:
- add Jenkinsfile (2008fdc)
peripheral.xarcade:
- add Jenkinsfile (f09a0e7)
pvr.mediaportal.tvserver:
- Update to v3.5.11 (PR:97, 4 commits, 5 files changed)
Includes latest addons: inputstream.adaptive (0bd5159, +5), inputstream.rtmp (ce7f559), peripheral.joystick (2008fdc, +1), peripheral.xarcade (f09a0e7, +1), pvr.argustv (609a2e7, +2), pvr.demo (964686d), pvr.dvblink (47cbff0, +2), pvr.dvbviewer (a9b204e, +8), pvr.filmon (f736ab4, +2), pvr.hdhomerun (a9d7309, +1), pvr.hts (f4ea60f, +2), pvr.iptvsimple (90a8d6f, +1), pvr.mediaportal.tvserver (e4a9dae, +2), pvr.mythtv (0517d4b, +17), pvr.nextpvr (7e36106, +2), pvr.njoy(4467cac, +1), pvr.octonet (203f800), pvr.pctv (e28a90f, +2), pvr.stalker (a99ad5e, +2), pvr.teleboy (bdbd6b2, +3), pvr.vbox (6ed2f63, +2), pvr.vdr.vnsi (6bbdb78), pvr.vuplus (d77458b, +2), pvr.wmc (e00c895, +2), pvr.zattoo (8ddb060, +7), vfs.libarchive (6d39012), vfs.sftp (6749200), pvr.sledovanitv.cz
Great! This seems to fix the thumbnail crash issue which was introduced in previous build.
Seems ok now, thank you!
Great. Thanks for confirming
17.8-349, 14 Nov 2018: Based off OSMC commit (91c8c4d) and xbmc (c895e84b9)
OSMC Leia Skin
- Provisioning addition of more widgets (ab99d7273)
XBMC:
- [settings] fix typo in UPNP setting description (PR:14851, 1 commit, 1 file changed)
- WebVTT subtitles (fb2d4ac)
- Version bump 2.3.8 (7f28ac0)
pvr.vdr.vnsi:
- fix failing load of vnsi caused by failing call to WakeOnLan (8627064)
- bump version to 3.6.2 (11df9b4)
348 and 349 both result in a frowny face boot loop for me. Dies when trying to load vsf.sftp addon.
removing the /usr/lib/kodi/addons/vfs.sftp directory allows it to complete the bootup.
I will see if I can bump the commit for vfs.sftp to the latest. Previously it was failing to build.
17.8-350, 15 Nov 2018: Based off OSMC commit (11ee72f55) and xbmc (8d710b3cf)
XBMC:
- [DetectDVDType]: fix Crash due to non-checked error state (PR:14842, 1 commit, 1 file changed)
- VideoInfoTag: fix missing field overview for sets (PR:14868, 1 commit, 1 file changed)
[*][docs] Adding FrameAdvance documentation (PR:14874, 1 commit, 1 file changed)
pvr.mythtv:
- update tag for radio channel to ‘’ (a43060c)
17.8-351, 16 Nov 2018: Based off OSMC commit (11ee72f55) and xbmc (8d710b3cf1)
OSMC
- Build with latest vfs.sftp commit
XBMC:
- Extend IsRemote check to some vfs paths (closes #14817) (PR:14860, 1 commit, 2 files changed)
- [docs] Trivial fixes to xbmc.Monitor docs (PR:14879, 1 commit, 1 file changed)
- [WVD] service certificate detection / share identical psshsets (1a374be)
- Version bump 2.3.9 (62980b9)
pvr.dvbviewer:
- fix ubuntu packaging (PR:76, 1 commit, 3 files changed)
pvr.wmc:
- fix ubuntu packaging (PR:64, 1 commit, 3 files changed)
17.8-352, 17 Nov 2018: Based off OSMC commit (d08a6ce64) and XBMC (8d710b3)
OSMC
- Revert PR 14755 (d9b5863)
- Vero4: Enable smart redraw
OSMC Leia Skin
- Improve media tags + bug fix
- Add “Please wait…” heading during busy dialog
- Add 8K resolution label
- Include codecId in decoder display name (3e6b8e6)
pvr.mythtv:
- add eit categories supplied by telerama (e88cd2f)
Just tried upgrading and it gives an error
Error Installing:
Please report this on the OSMC forum
Here are some logs:
https://paste.osmc.tv/ayaxamexen
If i try to proceed regardless then it says:
An error occurred while installing the following package: (unknown package)… and kodi is restarted 30 seconds later
There appear to be hash mismatches for the files in the repo
Do you want to continue? [Y/n]
Get:1 Index of /osmc/osmc/download/dev/gmc-18 gmc-18/main armhf mediacenter-skin-osmc all 17.9.3-15 [11.2 MB]
Err:1 Index of /osmc/osmc/download/dev/gmc-18 gmc-18/main arm64 mediacenter-skin-osmc all 17.9.3-15
Hash Sum mismatch
Hashes of expected file:
- SHA512:1937623d09d515da812e6dc8453f03231ad45b6ee32e63d61c5c496a6a68f031ce9b1693b9b0a568a578388e0bae2a01a8f089c234d8c1e23a6d5dc4dbb068ec
- SHA256:d8be043076c71d58c4b5cba4f14f678a281fd1a610ea5bc0a81370666e33d7d8
- SHA1:755f442745992933a3b3558614a9ea95acf38797 [weak]
- MD5Sum:7011ffa654fed241c12cb3bdb5c31fac [weak]
- Filesize:11157962 [weak]
Hashes of received file: - SHA512:5b022658c80d130302fbffaaf1321178a07c67ebd33904bef709d13af6a26c8eb86d1cc5c83a0bac131bcb75f065f49e3e63490f9f350d152823713c5d6c6a22
- SHA256:ae27e5f3deba39c71bd3cb088aae9cf9c9c503fd3ee3d01093c87d3bb0e2ea30
- SHA1:a85f7e9c7ca385d6ac7c5091b7d87755571d67c6 [weak]
- MD5Sum:e9e72abe737a7b35f90b3cbac5fe2812 [weak]
- Filesize:11154544 [weak]
Last modification reported: Tue, 13 Nov 2018 14:40:22 +0000
Err:1 Index of /osmc/osmc/download/dev/gmc-18 gmc-18/main armhf mediacenter-skin-osmc all 17.9.3-15
Hash Sum mismatch
Hashes of expected file: - SHA512:1937623d09d515da812e6dc8453f03231ad45b6ee32e63d61c5c496a6a68f031ce9b1693b9b0a568a578388e0bae2a01a8f089c234d8c1e23a6d5dc4dbb068ec
Get:2 Index of /osmc/osmc/download/dev/gmc-18 gmc-18/main armhf vero3-mediacenter-osmc armhf 17.8-352 [72.1 MB]
Fetched 83.3 MB in 12s (6,565 kB/s)
E: Failed to fetch http://download.osmc.tv/dev/gmc-18/pool/main/m/mediacenter-skin-osmc/mediacenter-skin-osmc-17.9.3-14.deb Hash Sum mismatch
I found a issue with the build and have pushed a new version of the skin (17.9.3-16)
Give it a hour or so to sync to the mirrors
When changing Settings>Player>Discs>Blu-ray playback mode to “Show Blu-ray menu” I get the following:
I’ve tried with both Openjdk & Oracle Java 8 installations.
DEBUG: DiscSettings - Could not load the java vm.
Debug logs: https://paste.osmc.tv/jugapivako
Has anybody else been able to get BD-J menus working?
17.8-353, 18 Nov 2018: Based off OSMC commit (4536612) and xbmc (f01060fc8)
XBMC:
- fixed: Low read rate detection logic when VideoPlayer uses filecache (PR:14869, 1 commit, 4 files changed)
- [storage] MediaManager::Onstorage*: Do not show toasts if fullscreen (PR:14881, 1 commit, 1 file changed)
- [fix] redact paths in edl logging (PR:14844, 1 commit, 1 file changed)
- [JSON] Bump version to 10.0.0 (PR:14790, 1 commit, 1 file changed)
- [addons] Sort logged list of installed add-ons (PR:14888, 1 commit, 1 file changed)
- Version bump 2.3.10 (df0dbd3)
pvr.mythtv:
- sync upstream cppmyth (2.11.0) (80396dd)
- disable file caching by default (1a0a9cb)
- add advanced settings to re-enable builtin files cache (19dc3d0)
- review visibility fo recording flags (6aa74d1)
- bump version 5.9.0 (d53d4b8)
Getting the same error. Will look into it.
@gmc the video calibration persistence issue is fixed now
thanks
