Hi. With the latest update the mysql db went from 112 (myvideos version for Leia) to 113 which makes it compatible for my other Leia devices. Does someone know the reason for that?
db version was bumped in this commit:
hmmmm⦠okay ty for the info.
17.8-381, 28 Dec 2018: Based off OSMC commit (90764f7d1d) and xbmc (8a178cd417)
pvr.zattoo:
- Update build steps (d44651f)
Includes latest addons:
inputstream.adaptive (efd4b4f), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv(83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (0aa6070, +1), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (d35dfcd, +2), pvr.iptvsimple (90a8d6f), pvr.mediaportal.tvserver (25e3e7d), pvr.mythtv (d3a5af2), pvr.nextpvr (450caeb, +1), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv(b60b971), pvr.stalker (2245b0d), pvr.teleboy (50689bd), pvr.vbox (6ed2f63), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (c3d984b, +1), pvr.wmc (2697409, +1), pvr.zattoo(4688f45), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)
17.8-382, 29 Dec 2018: Based off OSMC commit (c946f89d5) and xbmc (85486a286)
XBMC:
- fix CID 1441972 (PR:15140, 1 commit, 2 files changed)
- Do not list non-repo add-ons as āunavailableā in info dialog (PR:15099, 1 commit, 1 file changed)
- Fix unchecked reinterpret_cast of ID3v2 UFID frame (PR:15137, 1 commit, 1 file changed)
- [joystick.xml] Add more buttons to bring up OSD in LiveTV/Radio and Menu in EPG (PR:15038, 2 commits, 1 file changed)
- Workaround file copying bug decoding ā+ā to space in file names in add-on installation (PR:15109, 1 commit, 1 file changed)
- Scroll GUIListLabel on focus only when enabled (PR:15124, 1 commit, 2 files changed)
Vero3 build was corrupted so and busy rebuilding. Will be a few hours.
17.8-383, 30 Dec 2018: Based off OSMC commit (2d8460c78) and xbmc (85486a286)
XBMC:
- [keymaps] Specify that gamepad.xml is for EventServer āgamepadsā (PR:15138, 1 commit, 1 file changed)
- bump to v18.0 rc5 (PR:15152, 1 commit, 1 file changed)
Do these recent Leia builds for the Vero 4K+ include the various OSMC fixes that have been released in the last few months? For example the video improvement fixes for HDR and colourspace, and the network performance/stability improvements?
While I have some free time during this short holiday period I would like to get my media server up and running with a Leia VM for library updates and several Veros running Leia. Everything looks good in testing but I want to ensure I have the most recent fixes as I will not be touching the set up for a while after I go back to work.
If they donāt include the fixes mentioned, is there any way to manually apply these fixes to a Leia build?
As far as i know all fixes are included, but thereāve been various experimental kernels too!
Happy New Year to everybody !!!
Happy new year, @kid63!
Most of the patches have been syncād however there are some that no longer apply for Leia, and others that Iāve no managed to adapt yet for Leia due to the code being completely different.
As we head closer to a stable released of Leia these will be looked into.
Between 345 and 383 Iām loosing some audio passtrough to my pioneer avr. E.g. Dolby Digital Plus just dont work at all anymore.
When downgrading to 345 everything is fine again.
17.8-384, 2 Jan 2019: Based off OSMC commit (23ad399665b) and xbmc (b66ee8349)
OSMC:
- Vero 4K: add option to limit video output to 422; resolves issues with LG displays
- Vero 4K: update limited range switching patch to use unique identifier.
- Vero 4K: fix screensaver not working after a standby action; add support for standby and wake hooks
pvr.hts:
- Add support for recent tvheadend 4.3 image URL changes (HTSP v34) (PR:391, 2 commits, 5 files changed)
pvr.mythtv:
- add the implicit marks for begin or end (b83fb4c)
- bump version 5.10.3 (322f47d)
17.8-385, 3 Jan 2019: Based off OSMC commit (a128ec6a1) and xbmc (f7c721516e)
pvr.dvbviewer:
- [lang] updated language files from Transifex (3e1eae0)
pvr.hts:
- [lang] updated language files from Transifex (8a9d821)
pvr.nextpvr:
- More incremental bugfixes for seeking, GetStreamTimes() changes (PR:78, 1 commit, 6 files changed)
pvr.vbox:
- [lang] updated language files from Transifex (ea20464)
pvr.vuplus:
- [lang] updated language files from Transifex (185b311)
17.8-386, 4 Jan 2019: Based off OSMC commit (14295041) and xbmc (a9a7a2007)
XBMC:
- Coverity fix to remove switch implicit fall through (PR:15190, 1 commit, 1 file changed)
- [Estuary] display seekbar on showtime action (PR:15174, 1 commit, 1 file changed)
- Replace CREATE TABLE AS SELECT (PR:15092, 1 commit, 2 files changed)
- Resolution: Donāt add half refreshrates by default (PR:15016, 1 commit, 1 file changed)
- [SmartPlaylists] Define DynPath for items retrieved from library (PR:15132, 3 commits, 2 files changed)
- Add force flag to enable update file item in inactive window (PR:14998, 1 commit, 4 files changed)
- [wayland] Request new frame cb only when previous one was signaled (PR:15193, 1 commit, 1 file changed)
pvr.vuplus:
- Tuners and signal status (PR:156, 9 commits, 25 files changed)
17.8-387, 7 Jan 2019: Based off OSMC commit (66acdb218) and xbmc (b77a9e1c47)
XBMC:
- [database] Make season_view and tvshow_view SQL ANSI92-compliant (PR:15185, 1 commit, 1 file changed)
- [lang][skin.estuary] updated language files from Transifex
- Donāt add half refreshrates by default
- [docs] Fix layout of xbmcplugin.setContent
pvr.vuplus:
- Revert: move nlohmann-json to depends (PR:163, 1 commit, 10 files changed)
17.8-388, 8 Jan 2019: Based off OSMC commit (d7aeee9d) and xbmc (adb55e29f)
pvr.nextpvr:
- More fixes for live tv tsb and seeks (PR:82, 1 commit, 13 files changed)
pvr.hts:
- remove space so markdown link works in github preview (PR:392, 1 commit, 1 file changed)
17.8-389, 11 Jan 2019: Based off OSMC commit (cd577c56) and xbmc (7d27c5e2)
XBMC:
- Prevent crash when trying to resume audiobook with no chapters (PR:15213, 1 commit, 2 files changed)
in the last few test builds, the EPG shows the title and subtitles but the plot summary is missing. The windows and ubuntu Kodi test builds are showing the summary just fine fine.
17.8-390, 13 Jan 2019: Based off OSMC commit (290f3a7ca9) and xbmc (7d27c5e2d)
XBMC:
- [database] Set tvshow_view return maximum path (PR:15200, 1 commit, 1 file changed)
- VideoInfoScanner: Correctly redact URLs (PR:15228, 1 commit, 1 file changed)
I have a feeling the commits for this nightly donāt match the description. I was seeing a problem on a recent nightly with TV Shows being listed twice, and that is suppose to be fixed by PR:15200. As part of PR:15200 the videodb version was bumped to 116, but when I updated this morning to 17.8.390 (doubled checked this with the command line to get the version number) the videodb didnāt get bumped. Of course I didnāt figure that out until I had upgraded my Windows machine to RC5 (which has the videodb bump) and then deleted the 114 db. Luckily my video library isnāt huge, so I just rebuild it. But I did want to see if I had missed something obvious.
