gmc
14 February 2019 06:50
1015
17.8-418, 14 Feb 2019: Based off OSMC commit (cd84d5fed ) and xbmc (379f5f9903 )
OSMC Skin 17.9.3-42
“Hide video player OSD during pause” option fix
XBMC:
UPNPPlayer: Do not use memset on non-trivial type (PR:15485, 1 commit, 1 file changed)
[PATCH] [Binary Addon] provide API versions to addon for better
pvr.zattoo:
Add swb TV as reseller (PR:37, 1 commit, 4 files changed)
vfs.sftp:
Fix build issues due to libssh bug (PR:24, 1 commit, 1 file changed)
inputstream.adaptive:
WebM implementation (Vorbis ToDo) (bf18623)
Version bump 2.3.14 (5686514)
Fix WebM compile errors on VS2017 (c583da7)
version bump 2.3.15 (9a1f5d6)
inputstream.rtmp:
[depends] librtmp: openssl 1.1 patch fixes (PR:46, 1 commit, 2 files changed)
bump version to 2.0.5 (6065923)
Includes latest addons:
addons: inputstream.adaptive (9b944a5), inputstream.rtmp (ce7f559), peripheral.joystick (1f4225a), peripheral.xarcade (f09a0e7), pvr.argustv(83aa1e9), pvr.demo (964686d), pvr.dvblink (4ae42fe), pvr.dvbviewer (1ff63d4), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (dc35ade), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (9846896, +8), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv(b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (bb6babc), pvr.wmc (7b28be3), pvr.zattoo(c6ff1d2, +4), vfs.libarchive (6d39012), vfs.rar (0f56401), vfs.sftp (6749200)[/b]
gmc
15 February 2019 17:53
1016
17.8-418, 14 Feb 2019: Based off OSMC commit (6ddde351f6 ) and xbmc (379f5f99035 )
OSMC:
Game addons mame2000, mame2003, mame2003-plus
vfs.libarchive:
Add Exists() implementation (PR:28, 3 commits, 2 files changed)
gmc
16 February 2019 21:12
1017
17.8-420, 16 Feb 2019: Based off OSMC commit (44f2c35b32 ) and xbmc (112d31055 )
XBMC:
fixed: NFO/tag loading for http/https sources was broken (fixes #15481 ) (PR:15492, 1 commit, 1 file changed)
pvr.zattoo:
Add 1&1 TV as reseller (81ba94f)
Fiy case statement (30868ce)
vistree
18 February 2019 08:26
1018
As reported before, I also have problems with the suspend mode. Sometimes it works after suspending several times - but most often it directly stops suspend.
Did you experience this problem on Krypton, or only Leia?
vistree
18 February 2019 12:34
1020
I just started with OSMC by buying an new Vero 4k+ - and I directly upgraded to Leia. So I don’t know if the problem also exists in Krypton.
bendsch
18 February 2019 16:38
1021
18.1 is out! (just saying …)
gmc
18 February 2019 17:15
1023
17.8-421, 18 Feb 2019: Based off OSMC commit (140c099f7 ) and xbmc (5e82ff959 )
OSMC Skin
Version 17.9.3-43 PVR Channel number input bugfix
Version 17.9.3-44 Dialog Favourites Fix
XBMC:
bump for 18.1 final (PR:15486, 1 commit, 2 files changed)
bump to 18.2rc1 (PR:15535, 1 commit, 2 files changed)
[python] fix usage of line-breaks in ok dialog (PR:15434, 1 commit, 1 file changed)
[PVR] Document implict call to CloseXXXStream() before OpenXXXStream() (PR:15479, 1 commit, 1 file changed)
[estuary] Fix visual glitch when PVR info dialog activated from PVR channels OSD. (PR:15489, 1 commit, 1 file changed)
[Windowing] Build complete strmode for RES_DESKTOP (PR:15516, 1 commit, 9 files changed)
[HLS] effective URL for license (b76c81f)
k2u3
19 February 2019 09:13
1024
I think Sam is already baking a new osmc with kodi 18.1 included. Just make sure you don’t undercook or burn it
gpmc
19 February 2019 09:57
1025
Is there any 18.2 rc1 just on the way?
Are u waiting for this or 18.1 will be baked out?
danmed
20 February 2019 09:25
1026
I am running these test builds and they are great… but how do i know when it goes stable? And when it does, how can i switch to that one without wiping my box?
fzinken
20 February 2019 09:37
1027
You will see an announcement here in the forum and if you registered for the newsletter you will also get an email.
You will get the stable version automatically with the default update process. You then can just remove the GMC repository but that is more a clean up job then a necessity
With regards to this issue:
jahutchi:
Has anyone else tried time shifting in tvheadend (pvr.hts) on the Vero 4k+ using these test builds?
I’m finding that if I’m watching TV and hit the “Step Back” (left) button a few times, then the picture goes extremely juddery. It’s extremely easy to reproduce for me… happens every time.
I can stop the juddering by hitting pause, waiting a few seconds, then hitting play; so I can use this as a workaround in the meantime.
Timeshift is fine on other clients in my setup, when accessing the same TVheadend 4.2.5 server, those clients do not have this problem:
Generic HTPC running Kodi 17.6 under LibreELEC 8.2.5
RPI3 running Kodi 17.6 under LibreELEC 8.2.5
I wonder if this is one of those things that will improve when all patches etc. have been merged, as part of working towards the “Official” v18 builds?
I noticed that others are having the same problem with v18 Leia on other platforms over on the kodi forums, so I’ve also posted my findings there:
https://forum.kodi.tv/showthread.php?tid=325178
WRT the tvheadend timeshifting issue…
Looks like a change was made in v4.4.14 of pvr.hts (commit 2b7348), which should resolve the problem.
kodi-pvr:master ← ksooo:fix-isrealtimestream
opened 04:16PM - 17 Feb 19 UTC
Details can be found here: https://github.com/kodi-pvr/pvr.hts/commit/f6d248a766… fe1b6af318d7e66448e23f9bdb9565#r32349769
Any chance this can be bumped in the nightlies so I can test?
gmc
20 February 2019 15:30
1031
The next nightly will automatically include this fix.
gmc
22 February 2019 15:18
1032
17.8-422, 22 Feb 2019: Based off OSMC commit (9bb2084ca ) and xbmc (d21fed4ae3 )
pvr.hts
4.4.14 Fix HTSPDemuxer::IsRealTimeStream to always return true if subscription is active
pvr.dvblink:
Added: support for PVR_RECORDING.iChannelUid #115 (PR:116, 1 commit, 3 files changed)
Just to confirm, pvr.hts v4.4.14 fixed the livetv timeshifting issues I was having
