[TESTING] Linux 4.9 kernel and improved video stack for Vero 4K / 4K +
I have just installed this to finally get 1360x768 resolution but I can’t find it in the resolution menu.
Do I have to do something special to enable it?
Have you checked to see if your TV is advertising support for this resolution?
It would be unusual for a display to advertise 1366x768 over HDMI. Can you post debug logs after a reboot, please.
http://paste.osmc.tv/awiqosidot
2020-05-25 10:15:17.979 T:4070969344  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2020-05-25 10:15:17.979 T:4070969344  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2020-05-25 10:15:17.979 T:4070969344  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2020-05-25 10:15:17.979 T:4070969344  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2020-05-25 10:15:17.979 T:4070969344  NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2020-05-25 10:15:17.979 T:4070969344  NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
Your display offers only 3 VESA resolutions and not 1366x768 it seems.
when I had osmc running on my rPi it recognized 1360x768 without a problem
Hmmm. Please post the output of
cat /sys/class/amhdmitx/amhdmitx0/vesa_cap
640x480p60hz
800x600p60hz
1024x768p60hz
:thinking: You’ll have to leave it with us.
Try creating a file called disp_cap in /home/osmc/.kodi/userdata with the following contents:
480p60hz
576p50hz
720p50hz
720p60hz
1080i50hz
1080i60hz
1360x768p60hz
then restart kodi.
@sam_nazarko
Just installed version 20 and want to tell you that yellyfish 300 played fluently (via autofs on nas) :+1:
Understand you’ll go “ down under” to clean and work on further improvement. Thanks you and then team for all the effort so far. It’s been a pleasure to help us all with testing.
Looking forward to see those new build. Keep us posted. Stay safe.
That helps to get the resolution to show up in the settings, but when I select it the screen goes black for a while and then reverts back to 720p.
logs of the event:
http://paste.osmc.tv/ozocexipig
I wonder if you still have the Pi with OSMC around as the output of that might also help the team to understand the problem.
Please try:
echo 8bitnow | sudo tee /sys/class/amhdmitx/amhdmitx0/attr
then try setting 1360x768 again.
that did work! =)
I am posting the rPi1 logs anyway just in case they can help any further
http://paste.osmc.tv/rimodorive
Thanks for testing. We’ll get that fixed. For now, you will have to add a line to /etc/rc.local
echo 8bit > /sys/class/amhdmitx/amhdmitx0/attr so that you still get 8 bits on reboot.
Aahhh is the default 10bit these days?
Has been for a long time.
@Lagoon and anybody else getting the random picture drop while watching live TV.
I turned off the HDP lock in video settings and I haven’t had a single black screen in 3 days.
@CaptainMoody I tried my reproducer with “Lock HDMI HPD” either on or off, it doesn’t change anything.
