Wrong IP in your SSH? Do you have any Vero 4ks active?
I have no idea how that happened. I do have 4Ks but this is weird.
Here are the correct logs from the Vero V. These are slightly edited:
No sign of a DV-capable display in that log. Was a TV connected?
Yes. And it showed Dolby Vision on the TV when I started viewing the movies.
Thought Iâd do a quick test of Dolby Vision playback on my Vero-V (+ Yamaha RX-A2A/LG OLED48CX6LB)
After updating to to the development sources - âosmc-devl.listâ (noting that I am on kernel 4.9.269-72-osmc), I tried a couple of test files with the following results :
Profile 7 - âHybrid HDR10Plus DV Sample.mkvâ
The TV indicated in that it had detected âDolby Visionâ (top right hand corner of the screen), however the screen remained completely blank/black with the audio playing OK. -
Profile 5 - âdolby-vision-amaze-(dolby-vision)-(www.demolandia.net).mp4â
The TV indicated that it had detected âDolby Visionâ, the screen remained completely blank/black with staggered audio playback. -
Profile 4 - âLG Demo DolbyVision Comparison.mkvâ
Seemed to play OK, but TV did not detect this as DV.
The debug log is here https://paste.osmc.tv/arocabiriv and should show these three attempts.
Is there an obvious answer to this ? Do I need to adjust any settings on the TV ?
The Vero-V Player Settings were set to allow DV (i.e. HDR processing is set to HDR (Auto)).
Hi Chris
Regarding Profile 4: please see the Implementation section of my original post. This is expected behaviour.
Will check the other issues reported shortly. Thanks for the log.
Attached - the media info for the Profile 5 & 7 test files.
General
Unique ID : 3736423639910948765621438168939931369 (0x2CF9BE88ED326E323838709A1DCA6E9)
Complete name : G:\Media Files\#video nbu\#Test\Dolby Vision\Hybrid HDR10Plus DV Sample.mkv
Format : Matroska
Format version : Version 4
File size : 510 MiB
Duration : 1 min 0 s
Overall bit rate : 71.3 Mb/s
Frame rate : 23.976 FPS
Movie name : Alpha (2018)
Encoded date : 2023-08-10 21:59:41 UTC
Writing application : mkvmerge v78.0 ('Running') 64-bit
Writing library : libebml v1.4.4 + libmatroska v1.7.1
Video
Format : HEVC
Format profile : Main 10@L5.2@High
HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile B, HDR10+ Profile B compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 69.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.348
Stream size : 495 MiB (97%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 6392 cd/m2
Maximum Frame-Average Light Level : 997 cd/m2
Audio
Format : MLP FBA
Format/Info : Meridian Lossless Packing FBA
Commercial name : Dolby TrueHD
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 2 040 kb/s
Maximum bit rate : 3 738 kb/s
Channel(s) : 6 channels
Sampling rate : 96.0 kHz
Frame rate : 1 200.000 FPS (80 SPF)
Compression mode : Lossless
Stream size : 14.6 MiB (3%)
Title : Dolby TrueHD 5.1
Language : ine
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 12 s 929 ms
Bit rate : 42 b/s
Frame rate : 0.232 FPS
Count of elements : 3
Stream size : 69.0 Bytes (0%)
Title : Forced for non-English dialogue
Language : English
Default : Yes
Forced : Yes
Menu
00:00:00.000 : en:Farewell
ReportBy : MediaInfoLib - v24.12
CreatedOn : UTC 2024-12-20 09:53:37
General
Format : Matroska
File size : 510 MiB
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Language : English
Default : Yes
Forced : No
Audio
Format : MLP FBA
Codec ID : A_TRUEHD
Language : ine
Default : Yes
Forced : No
Text
Format : UTF-8
Bit rate : 42 b/s
Language : English
Default : Yes
Forced : Yes
Menu
Thanks for the report. Regrettably, you re-booted after playing those clips so the kernel log doesnât cover the time when you played them.
Can you repeat the P5 and P7 clips after turning off re-scanning the library on restart and rebooting. It looks like your logs may have been too long to upload.
If possible, can you try connecting Vero direct to the TV?
Thatâs interesting. I just checked that Amaze download and got this (very different)
General
Complete name : C:\Users\graham\Downloads\dolby-vision-amaze-(dolby-vision)-(www.demolandia.net).mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 190 MiB
Duration : 56 s 200 ms
Overall bit rate : 28.4 Mb/s
Frame rate : 60.000 FPS
Encoded date : 2017-04-13 20:09:18 UTC
Tagged date : 2017-04-13 20:09:18 UTC
Video
Format : HEVC
Format profile : Main 10@L5.1@Main
HDR format : Dolby Vision, Version 1.0, Profile 5, dvhe.05.09, BL+RPU, no metadata compression
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 27.7 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.056
Stream size : 186 MiB (98%)
Codec configuration box : hvcC+dvcC
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Format settings : Dolby Surround EX
Codec ID : ec-3
Duration : 56 s 192 ms
Bit rate mode : Constant
Bit rate : 640 kb/s
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 4.29 MiB (2%)
Service kind : Complete Main
Complexity index : 14
Number of dynamic objects : 13
Bed channel count : 1 channel
Bed channel configuration : LFE
Dialog Normalization : -31 dB
compr : 0.53 dB
dmixmod : 3
ltrtcmixlev : -3.0 dB
ltrtsurmixlev : -3.0 dB
lorocmixlev : -3.0 dB
lorosurmixlev : -3.0 dB
dialnorm_Average : -31 dB
dialnorm_Minimum : -31 dB
dialnorm_Maximum : -31 dB
Completely different profile. Chrisâ Amaze video isnât Profile 5 at all which is oddâŚ
No. The 2 mediainfos he posted are the same.
I turned off library scanning+rebooted twice and repeated the profile 7 & 5 tests, with HDMI connections Vero-V > Yamaha RX-A2A > LG-OLED48CX6LB
Profile 5 - âdolby-vision-amaze-(dolby-vision)-(www.demolandia.net ).mp4â
Logs - https://paste.osmc.tv/kikibavisi
HDMI connection: Vero-V > LG-OLED48CX6LB
Results for the Vero-V connected directly to the TV were the same (i.e. blank/black video, with Dolby Vision detected), except for the audio which played correctly for profile 5 (i.e. it wasnât staggered and suggests the AVR is limiting performance throughput to the audio in some way).
Simply put thatâs profile 5 as opposed to 7 and the audio EAC3-JOC as opposed TrueHD. I think the âdemolandiaâ site previously had other versions of these test files.
Iâve uploaded the profile 5 & 7 test files I used to my Google Drive, here:
VIDEOs DELETED
Can you try setting adjust refresh rate to on start/stop?
I have exactly the same files here. You have two settings which are different from mine:
- quantization set to full-range. This is not necessary and could be counter-productive
- refreshrate set to Always. Thereâs an internal debate here about the best setting. Iâve always set it to On start/stop
I changed my settings to match yours and got an occasional blank screen with Amaze but mostly it worked OK. I havenât yet had a blank screen with the Hybrid clip.
Thanks Graham,
A change of the âDisplay Refresh Rateâ to START/STOP made no difference, so I have kept that set at ALWAYS (settings>player settings>videos).
A change to âUse Limited Colour Rangeâ from OFF to ON, made all the difference and video playback for the two test files (and others) was restored (settings>system>display).
However, the audio on playback of the Profile 5 file - âdolby-vision-amazeâ still has staggered audio playback. The AVR status display seemed to indicate that it wasnât happy with the audio format and kept randomly switching from âdecoder offâ to âDolby ATMOSâ, furthermore this wasnât a problem with the Vero-V connected directly to the TV (as the audio is down-converted to AC3 before being passed back to the AVR using the HDMI âARCâ (and not eARC)).
On occasions after stopping/starting (seeking) I have noted the display colours revert to the purple/green combination, this was then only resolved by rebooting. I think this is probably a file with some irregularities format wise, as many other DV + ATMOS files that I have played fine, both audio and video.
This âirregularâ DV Profile 5 file is here, and it would probably be a good idea to take a deeper look at this.
Interesting, thanks.
My AVR doesnât do Atmos but my TV says it does FWIW. Iâll check that out. I wonder what the current release OSMC would make of it (ie is it because of our DV implementation or is it a problem with the file). I wonder about the parentage of that Amaze clip. I have a version thatâs slightly different and someone once posted a clip of it which was different again.
What do you mean by that? Stuttering?
Stuttering is probably a better word, nevertheless staggered wrt time.
The audio repeatedly stops and starts with short silences of variable lengths, usually less than a second at most.
Is it more like itâs dropping out? Youâre hearing half the audio and when it comes back you hear half of that too?
Yes, I think its dropping out and is also out of synch.
At the very end of the playback, as can be seen in the video below, it seems the audio is out of synch with the video stream. When the video stream completes the stuttering audio stream continues.
VIDEO DELETED
Of all the DV video file playbacks I have tried, so far, this is the only one with this issue on the Vero-V.
All I can say is I canât reproduce that here - playing direct to my TV which indicates both DV and Atmos. Not using ARC.
We would need debug logs with the video component and audio sync component engaged to investigate further.
Let us know if you find any other vids with that quirk.
