[Testing] X11(simple desktop) + Chromium(web browser) in a simple installer for Stretch
As long as it’s in the debian for armhf it should be doable, but remember it’s a device with limited memory.
I try with ssh, sudo apt-get install p7zip and the installation is ok but I didn’t found my installation.
have you restrted X?, sometime that’s needed to get it in the “start menu”
Yes I have restarted X and nothing.
Package: p7zip (16.02+dfsg-3)
7zr file archiver with high compression ratio
p7zip is the Unix command-line port of 7-Zip, a file archiver that handles the 7z format which features very high compression ratios.
That’s from debian stretch, so no Xwindows support, unless you run it in terminal
Here is an alternative for you, I’ve not tested it. http://www.peazip.org/peazip-linux-arm.html
Thanks ! I try to install peazip
The installation doesn’t work.
Ssh : sudo http://www.peazip.org/peazip-linux-arm.html → Download ok
sudo apt-get install Peazip-for-ARM
And nothing
It’s not a -deb file and apt-get installs from the repository.
tar zxvf pea-gtk2-arm.tar.gz
then you got a folder in osmc home directory that contains among others an executable file, which you can start from command line or learn howto make an icon in lcde desktop (google is your friend).
Ok thank you. I will try to do this.
Another question, do you know if a sopcast player can be installed on osmc like Ubuntu?
Thank you.
Well even if it can be installed it would not be Hardware accelerated so quite useless.
Hi @joakim_s
Do we need to run the installer again after updating to stretch?
During the stretch december update noticed osmc error on file desktop-file-utilts.
Im running the update again see if it solves it.
it should be solved by installing that package only after update, if it fails.
sudo apt-get install desktop-file-utils
Reinstall is not needed, but recommended, since there is a change in x_init.sh which you can edit yourself by copying the row under “startx” so the same line in above too.
I would do a clean stretch and then install my plugin, since you get the new chromium that comes with Stretchs Chromium v.63 (still no accelleration :frowning: )
Thanks for reply
What line do i need to add to x_init.sh. Here is my file
#!/bin/bash
sleep 2
sudo fbi -T 7 -d /dev/fb0 --noverbose /home/osmc/Pictures/Desktop/lxdewallpaper.jpg &
sleep 3
sudo su osmc -c “startx”
sudo openvt -c 7 -s -f clear
exit
I installed new version of chromium manually before. Ill try manual install v63. Is this the correct file?
https://launchpad.net/~canonical-chromium-builds/+archive/ubuntu/stage/+build/13832764/+files/chromium-browser_63.0.3239.84-0ubuntu0.17.10.1_armhf.deb
Yeah pity about no accelleration. Guess stretch didnt make it any easier.
Thanks for trying anyways :slight_smile:
sudo apt-get install chromium
tht will give you debians chromium v.63, this approach will not replace your v.51 so you will have two chromiuma installed.
copy line 6 and insert that on a line before startx line
so it this correct?
#!/bin/bash
sleep 2
sleep 3
exit
If i install v63 manually like same way i installed before stretch will that replace the version and not have two chromiums?
Is there a difference between the apt-get method and the manual install. Do you recommend installing from the apt-get install method?
Yes looks correct.
About replacing chromium i’m not sure, i never tried. I allways do a clean install, but i got like 2 plugins, both my own. +netflix and viaplay in leila, but i’v just gone back to v.17 again.
Off topic i know - but will this script work on Libreelec.TV build ? Im running a Odroid C2 unit (so i get 4k HDMI playback), and would love to be able to launch a desktop from Kodi.
You mentioned also about the process of Quit Kodi > Launch desktop > Quit Desktop > Launch Kodi any way to achieve that?
AFAIK no apt-get capability on libreelec so the other is NO
Well interesting enough someone recently asked the question in the libreelec forum
My variation is that I only want to run the X desktop manager remotely. From your setup, it looks fairly generic so obviously does not install the “mesa” stuff. Somewhere along the line over the last 2 years, the “mesa” stuff has arrived on my Pi.
But it does give me greater confidence that I will eventually make it all work with the proviso that some future update may blow it up again.
I can actually live without Kodi (ON the Pi) for a while as a TV update last year vastly improved the capabilities on that side so my TV can see all my videos incl. recordings anyway.
Joakim_Sandstrom…
I see you are trying to build an accelerated chrome for our Vero boxes (i myself got a vero4).
Do you know if it will ever be possible to use this plugin with HBO-Nordic?
I am not so much into this but have read somewhere that HBO Nordic use flash plugin, or html5 player (not sure about this)…
After Netflix is working on v18, it would be cool to have HBO working also, and if thats possible, i think osmc shop will be quickly emptyied :grin:
What do you think?
(( Ohh… btw i have this HBO Nordic, so i can try whatever.
Also i got a linux mint laptop here, but i didn’t get it to work yet ))
I will investigate some more about howto play HBO Nordic content.
Rgds; Jesper.
Despite the installer script finishing with a “Thank you for using my installer”, there was no option to enable the X11 Launcher in My add-ons. Scrolling up in the terminal I found:
 /tmp/apt-dpkg-install-mQ2u6w/044-gnome-icon-theme_3.12.0-2_all.deb
 /tmp/apt-dpkg-install-mQ2u6w/078-chromium_63.0.3239.84-1~deb9u1_armhf.deb
How to proceed now?
Thanks.
