If you use osmc remote and If you click home button and this not launching virtual keyboard
open lxterm
and install any text edytor ex.gedit
open /home/osmc/.config/openbox/lxde-rc.xml
And search <!-- Keybinding for i CONTROL Xvkbd
and under
in this passege
keybind key=“Home”
change “Home” to “Escape”
beceuse Home button is probaly not defined
Because osmc remote is like a keyboard
and home button clicking Escape
Escape is defined as keyboard button
and osmc remote if you click home button sends
to your raspberry or vero Escape
i make osmc remote script
for the best Impressions
Now i’m thinking how to change buttons actions in remote
because openbox shortcuts don’t delate first action
sorry for bad english
I have only pi 3 b+
you can download it here:
But it’s have testing status
later i remove this status for rpi 3 b+
note:First release have Work In Progress status
Thank you for the feedback, PRs are appreciated
I maked the auto remote detect script
To install enter to terminal
Cd /home/osmc
Wget https://raw.githubusercontent.com/rebokdev/owbef/patches/vmkd/installer.sh
Chmod +x installer.sh
Sudo ./installer.sh
If you found bug please make issiue on github:
KDE Plasma has a DE version specifically for TVs, I think It could be nice to use that as a desktop for OSMC
I will put this on the “check out for v.2.0”, no promises. Seems “semi easy to use the neon version for a conversion to OSMC-pi4”. But I can’t do a a OSMC desktop for just one HW platform, there are some good news like it’s wayland based and that makes it a bit easier for vero4k driver wise. But still have to have a deep dive into it and no time for it right now.
Thanks, I’m happy you’re interested
Seems to be issues with X-windows and Bullseye upgrade, if you got issues. I’ve got an attempt to uninstaller.sh, in addons the github-tree. Try that, I dont have it installed on any machine I’m able to update at present.
Got two ideas to check against:
- graphics driver is compiled against older libs(Vero 4k and +)?
- due to distribution upgrade, the dependency of graphical login service is actuated again, but the service is disabled?
Has anyone tried streaming from Medici.tv on Vero 2?
If you are considering playing any video in this Xwindows solution, I recommend you drop that idea. There is no video acceleration in any OSMC hardware platform right now.
Ok, thank you. Maybe that’s off-topic, but is there any way I can stream from a web page on vero 2 with osmc/kodi?
hi,
got this working well on my vero4k. 3 quick questions :
- Is there a way of having a guest account that can auto login?
- is there a way of rotating the display 180’? I’ve got a portable lcd screen that I want to have running showing my server diagnostics but the connections on the screen are on the other side that makes mounting awkward.
- Is there a way of auto starting chromium to load up a webpage on login?
Basically I have my unraid server running and I want promethius (or some such) running showing everything I need to keep an eye on it.
Cheers!
If you look at “/home/osmc/x11-start/x_init.sh”, at line 8 you chose which user that is going to “own” the X-server session.
There should be, at the moment I’m a bit unsure which route to do it, will get back to you. Been months since I had this project up and running =)
Edit “/home/osmc/.config/lxsession/LXDE/autostart”, enter a new line at the bottom. Something like this (remember this is from memory): @chromium “http://unraid-ip:port”
Hope that helps, I will have to check how I would solve it, might be as simple as installing xrander, but I’ll have to check it out.
Goodluck
Thanks for publishing this easy to use script! I just used it to install X11 & Chrome on my Pi4 OSMC system. It worked fine, and after enabling the X11 Launcher addon I was able to start the desktop and through it Chrome.
Before my first reboot directly after installing, I had the problem that websites complained that I’m missing DRM features in my browser, that was fixed by rebooting.
Problems I still have:
- everything looks super tiny and I have to get really close to my 4k TV to be able to read & control the desktop → missing High-DPI scaling.
- Videos played through websites in Chrome show me about one frame every 2-3 seconds. Very unusable unless I’m only interested in the sound, which worked fine. → missing hardware acceleration?
Does anybody have pointers for me how I can workaround / fix those issues on my Pi4?
When it comes to hardware acceleration, i’m all out of time and ideas to get it to work in OSMC, sorry to say but I gave up when a chrome compile took almost 30 hours on my old laptop.
Dpi scaling, there was someone who had a solution earlier in the thread, I had planed to integrate it. but it has fallen n the back burner.
I moore then welcome for PR’s on github, version two is planned to have some switching between kodi and X on some platforms. But it’s for a rainy day…
thanks, worked fine for me too on my pi4
