Works great so would I need to install another window manager or can I use the one installed to support VCNServer?
or am I wrong and he VNC_server isn’t using xwindows at all?
Second question
If VNCServer uses a Xwindow manager and you can use the xwindow items that support it is it possible to switch between Kodi and chromium using virtual windows or something similar to alt-tab?
in order to get the vnc-server to work with your xxwindows installation remove medicenter service as required in the service file, then vncserver wont close when kodi does:
[Unit]
Description=VNC Server
After=network-online.target
Requires=network-online.target
Second question, as I see it there is no way of alt-tabing between kodi and Xwindows right now. I tried running Kodi from within X but Kodi wont let me alt-tab out of it.
Lol, I’m not a coder at all, just a script mechanic. About JNLP files, after googleing some, I dont think it’s gonna be an easy task, if even possible. Found this when searching:
No webstart or plugin available for the ARM
This is beyond my knowledge, so I don’t think I can help you, sorry.
