Dear all,
I have a Raspberry Pi3 connected via ethernet.
I have connman working to create a wifi hotspot tethered to the ethernet. I have added the route as described in Tethering and OpenVPN - #2 by matosch
iptables -t nat -A POSTROUTING -o tun0 -j MASQUERADE
It all works fine to connect my phone to the wifi created.
Now I added OpenVPN, and simply enough it works and ipinfo.io shows me in another country from both the Pi directly and the devices connected over wifi.
However, I would like to only route the wifi traffic over the VPN and leave the rest of ethernet traffic to go through my regular gateway so that I can SSH into my Pi from outside the network.
My attempts have included adding route-nopull and route 192.168.1.0 255.255.255.0 to my OpenVPN config as described here windows - OpenVPN: Only route a specific IP addresses through VPN? - Super User but it stops all traffic working on the devices over wifi.
I have messed around with the iptables a bunch but I think I am running out of trials to error.
How can I route all wifi traffic (192.168.1.*) through the established tun0 without affecting ethernet traffic?
I could live with all traffic going through the VPN if I can set a route to be able to access the Pi from outside the network, maybe this is easier?
Here are some outputs of relevant files in the working state: Please ask for more if it helps:
root@RaspberryPi:/# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
10.8.2.0 0.0.0.0 255.255.255.0 U 0 0 0 tun0
192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.0.1 0.0.0.0 255.255.255.255 UH 0 0 0 eth0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 tether
The route nat table:
root@RaspberryPi:/# iptables -L -t nat -n
Chain PREROUTING (policy ACCEPT)
target prot opt source destination
Chain INPUT (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
connman-POSTROUTING all -- 0.0.0.0/0 0.0.0.0/0
MASQUERADE all -- 0.0.0.0/0 0.0.0.0/0
Chain connman-POSTROUTING (1 references)
MASQUERADE all -- 192.168.1.0/24 0.0.0.0/0
Hope somebody can help, it’s driving me crazy. Thanks
