My OSMC Pi3 is connected to my router via ethernet.
I am trying to tether a Portable Hotspot Ethernet to Wifi so that I can connect to this hotspot with my iPhone and using OpenVPN effectively be in the same virtual location as my Pi3.
I can connect to the hotspot, but with OpenVPN enabled I have no internet on my iPhone (though I do on the pi3 itself).
I have set up connman-vpn using this config
[global]
Name = BTGuard
Description = VPN for BTGuard
[provider_openvpn]
Type = OpenVPN
Name = BTGuard
Host = vpn.btguard.com
Domain = btguard.com
OpenVPN.CACert = /home/osmc/vpn-conf/btguard.ca.crt
OpenVPN.Proto = UDP
OpenVPN.Port = 1194
OpenVPN.AuthUserPass = /home/osmc/vpn-conf/login.txt
If I run connmanctl vpnconnections I can see the vpn connection
BTGuard vpn_btguard_com_btguard_com
With OpenVpn stopped the iPhone connected to hotspot can surf the internet, with it started nada.
Guessing it has something to do with iptables but not sure where to start
