Is there any way to be able to configure and monitor what goes on.
Like seen who is connected, what ip have been given, how many people are connected, etc
If you figure out how to extract such info with the connmanctl command, maybe, but I’d be surprised if connman provides for such.
I am not a linux wizard, hence I use my mobile for loads of network stuff.
If you are connected with your mobile on the same network than use “Fing” by Overlook and do a network scan, you can see who is connected on the same ip range
netstat will probably be sufficient
