I came from alpha 4 and failed to get tethering working on there. Then I installed the clean RC and did the last update scan about 3 minutes ago. Rebooted and everything seems fine.
Now I try doing tethering again but it still doesn’t work… I tried doing it from the GUI this time, but I get the error message
Error enabling hotspot - see log for details
When trieing via SSH I get
Error enabling wifi tethering: Not supported
Without this **** connman (sorry but this has only caused problems for me over the standard linux networking) it works flawless (tested on raspbian)!
Here is dmesg from my Wifi Stick (I tried tethering when plugged in directly into the pi and into a self-powered hub)
[ 2.973185] usb 1-1.5.2: Product: 802.11n WLAN Adapter
[ 2.973202] usb 1-1.5.2: Manufacturer: Realtek
[ 2.973217] usb 1-1.5.2: SerialNumber: 00e04c000001
[ 3.062101] usb 1-1.5.4: new high-speed USB device number 6 using dwc_otg
[ 3.172622] usb 1-1.5.4: New USB device found, idVendor=13fd, idProduct=1840
[ 3.172656] usb 1-1.5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
When I did dmesg it was plugged in directly to the pi without a hub. How do I activate max_usb_current? And when I do, should it be plugged in to the selfpowered hub or to the pi directly?
Using a powered hub max_usb_current is not necessary. If you aren’t using a hub, it can be activated in the pi config options in MyOSMC followed by a reboot.
