I am running the latest version (I think, I’m not sure where to confirm that?) and I have set my IP address to manual, turned on Wireless device and configured tethering ethernet to wifi.
The hotspot is created and I can connect with my phone but it has no connection, and looking at the wifi settings on the phone it shows the IP is not available. I have tried to search for which DHCP server that OSMC uses but I can’t find anything. Is the DHCP provided by connman? I am new to connman and don’t know how or where to change the settings for some things but I am comfortable using the terminal via ssh.
It would also be nice to change the allocated IP’s of the tether, at the moment in ifconfig
it shows my tether as 192.168.3.1 and I’d rather have this set to 13.0.0.1 or similar to identify this traffic for iptables, at the moment it sometimes changes the 3 in that address to a 1 or a 2.
I also ran into another problem before where connman doesn’t seem to get internet connection via ethernet. I fixed this by putting a sleep 30 and service connman restart
into the startup script, not ideal but it works now but just curious if the problems are connected?
Any help would be appreciated, I am happy to provide logs and config settings if required.
