The v2 of this wifi dongle has always been difficult to get running on a Raspberry Pi. However, at the moment, it should be supported by the kernel. I used to use raspbmc and installed a custom hostapd and a driver that I compiled myself. This works like a charm.
Every update broke the driver but using the script, it wasn’t too hard to re-compile and be up and running in no-time.
Then, OSMC was introduced. I tried the very first version but didn’t get the hostapd running. Today, I installed RC3 and saw there’s a tether function availabe from the gui! So I tried immediately: I enabled the wifi (which worked), then I enabled the tethering (ethernet to wifi) but that fails every time.
From the commandline, I executed connmanctl tether wifi on osmc passwddddd but got the error
connmanctl> tether wifi on osmc passwddddd
Wifi SSID set
Wifi passphrase set
Error enabling wifi tethering: Not supported
So now I’m lost. What can I do to make this work?
On a trip/vacation, I’m used to take the raspbmc box with me, preloaded with some movied (mostly childrens movies to get the children asleep abroad ) which I can control using my phone and without the requirement for any other network being available.
I’d like to use osmc but this is keeping me from using it full-time (only at home where I connect it using ethernet)
Check with dmesg to see which driver your adaptor is using - not all of the drivers currently support hostap mode - for example the rtl8192cu driver we are using currently isn’t supporting hostap (tethering) mode. We hope to get this fixed at some point but isn’t easy or we would have done it already.
However, the lines I see in dmesg are these (and I’m confused because they don’t mention the r8188eu driver)
[ 2.284052] smsc95xx v1.0.4
[ 2.362160] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:91:c0:3d
[ 2.440580] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 2.541216] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8179
[ 2.541260] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.541278] usb 1-1.2: Product: 802.11n NIC
[ 2.541294] usb 1-1.2: Manufacturer: Realtek
[ 2.541310] usb 1-1.2: SerialNumber: 00E04C0001
