My setup:
My RPi 3 with OSMC is connected via wifi (external usb) to my network. I like to share this connection with my TV (ethernet).
So I plugged in a cable and switched tethering (wifi → ethernet) in myosmc on.
The TV does not get internet.
I tried it twice:
Try
http://paste.osmc.io/qusiyejaya.vhdl
Try (after installing ifupdown)
http://paste.osmc.io/icewiyonip.vbs
My network has the range 192.168.0/24
I am wondering about the 192.168.1.1 IPs in the log files.
Is was not successful with google
Do I have to disable it on my router or on the pi?
Use the forum’s search feature.
Type DNS proxy and click the first result.
IP range will be different as we use NAT with ConnMan
Ok thanks
This was already in /etc/connman.prefs
Sorry, it should be enabled
Ok thanks but it still does not work:
http://paste.osmc.io/henifapaju.pas
Jan 25 14:08:25 osmcwohn connmand[285]: Failed to bind UDP listener socket
Jan 25 14:08:25 osmcwohn connmand[285]: Failed to bind TCP listener socket
