Whenever I try to run sudo apt-get install upstart I am presented with the below (It seems apt-get is trying to remove packages needed)
osmc@osmc:~$ sudo apt-get install upstart
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
cgmanager cpio ifupdown initramfs-tools iproute2 klibc-utils libcgmanager0
libdrm2 libjson-c2 libjson0 libklibc libnih-dbus1 libnih1 makedev mountall
plymouth systemd-shim
Suggested packages:
libarchive1 ppp rdnssd bash-completion iproute2-doc desktop-base
plymouth-themes pm-utils python3 graphviz upstart-monitor
Recommended packages:
isc-dhcp-client dhcp-client libatm1
The following packages will be REMOVED:
rbp2-device-osmc systemd-sysv
plymouth systemd-shim upstart
0 upgraded, 18 newly installed, 2 to remove and 0 not upgraded.
Need to get 0 B/2051 kB of archives.
After this operation, 5524 kB of additional disk space will be used.
(Reading database ... 33568 files and directories currently installed.)
Removing rbp2-device-osmc (1.3.9) ...
WARNING: You have tried to remove a package that is essential to OSMC's operation.
To undo these changes, run 'sudo apt-get -f install'.
dpkg: error processing package rbp2-device-osmc (--remove):
subprocess installed pre-removal script returned error exit status 1
rbp2-device-osmc
Update rpimonitor Packages Status
I have tried the following commands to fix the issue:
sudo apt-get -f install rbp2-device-osmc --reinstall sudo apt-get -f install systemd-sysv --reinstall sudo apt-get update && sudo apt-get -f dist-upgrade
But none of them seem to have worked.
- The issue you are currently experiencing with OSMC: Answered Above
- What you were doing when this issue occurred: Trying to install upstart using apt-get
- Whether you can replicate this issue on demand. If you can, then please provide some steps on how an OSMC developer can reproduce the same issue. sudo apt-get install upstart
- The device you are currently running OSMC on Raspberry Pi 3
- What peripherals are attached to the device? STK1160 Chipset USB capture card
- Has this issue been introduced by a new version of OSMC? When did the issue first appear and can you recall a time when it was not present? I donât think the issue was present before the April OSMC update
Please find the logs for my install at the following address: http://paste.osmc.tv/hitetoxuje
Note: I rebooted the pi, logged into it via SSH and run the apt-get install command, after this uploaded logs.
Any help is appreciated.
