Dmozer
1
I am in the US and I am contemplating ordering the dvb-t2 tuner. Unfortunately the forum information is both disparate and out of date mostly.
Is the osmc tuner really plug n play with tvheadend setup?
Does it work for the radio menu option also, or just live tv?
Thanks!
It will work on your Pi without issue. No idea about DVB-T2 signals in the states however. Where are you based?
Radio should also work fine.
Unless you are aware of any DVB-T2 distribution in your area you should not go for this Dongle.
I believe US is still using 99% of all times ATSC.
Dmozer
7
Ok. I can deal without tv in the truck. But radio will work, you say?
I’m in New Mexico.
For DVB … “radio” usually means a TV signal with no video.
AFAIK the OSMC DVB tuner will not pick up FM, AM, DAB (not applicable in USA) or HD Radio.
Dmozer
9
Thanks, paulwebster! I’ll keep trying to get my rtl-sdr 2832u working then. Dmesg sees it, but tvheadend does not.
