Video clips do not create thumbnails on vero 2 and the setting is checked to do so
You are giving us pretty much zero info to work with here. What menu? Added to library? What skin?
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Our wiki contains detailed steps for providing the relevant info we need to help you.
Is ‘Extract thumbnails from videos’ enabled?
If you have a library mode, then the image will come from the scraper
Yes this is enabled movies and tv shows work fine with scrapers these are just short video clips
A debug log may give some clues here.
Do the clips play correctly themselves?
BallGirlCatch.zip (6.0 MB)
yes they do play this is the kind of clips I am talking about
