I’ve been trying to use the Tidal player for streaming HiFi. So far I have been unsuccessful. What I have,
RPi 2 B
OSMC 01012016,
I think Kodi Jarvis RC3 ( I ran wget http://paste.osmc.io/raw/afopazadum -O- | sudo bash )
and Tidal 1.2.2
With the PAPlayer it will say opening stream a few times then error out and say to check logs
With the BTPlayer it looks like it opens the stream OK and goes to a player widow with the player controls, but nothing will play. It usually comes up waiting for the play button to be pressed which I do but nothing happens, the time counter just stays at 0.
The DVDPlayer is much like the PAPlayer where it tries a few times then quits.
From the behavior I would say the BTPlayer is the one for FLAC files, but doesn’t work.
Sometimes it looks like it should be playing but nothing happens.
Looking through various posts, it seems the FLAC decoder should be there and ready to go.
Pandoki, and Tidal when not HiFi work fine.
I did a grab-logs -A, they are at,
http://paste.osmc.io/erewosubej
The first audio related failures I see are in the kodi log at 16:40:36
Joel
