Time setting in Vero2
Gang,
I’m drawing a blank here. Where does one adjust the time settings in OSMC (Krypton update) on Vero2 box? I can’t seem to find it in the system menu or in My OSMC. Any help is much appreciated!
Sam,
You guys keep up the great work!
You mean change the actual time or the timezone?
Timezone is in Settings → Interface → Regional
Thanks for the kind words.
Let us know if you run in to any problems :slight_smile:
The ACTUAL time. Time zone is correct, but time is off by 2 hours 54 minutes (behind)
Reapplied each setting and rebooted, now all is good.
As long as you have a network connection that will be automatically be set.
If you need to set it manually you would need t do that via command line.
