Timeline on updating to Trixie?
Python3.9 is deprecated with some tools like yt-dlp and as such which breaks functionality in a few addons.
So what is the timeline for upgrading to a trixie base and get the latest python stuff?
TIA
Edit:
To forestall any suggestions to use the python-backports. That does not seem to be a good idea.
apt full-upgrade
Reading package lists… Done
Building dependency tree… Done
Calculating upgrade… Done
The following packages were automatically installed and are no longer required:
armv7-bluez-osmc armv7-bluezalsa-osmc armv7-connman-osmc armv7-libbluray-osmc armv7-librtmp-osmc armv7-libshairplay-osmc armv7-libsqlite-osmc avahi-daemon cifs-utils curl gir1.2-glib-2.0 iproute2 iptables
libatomic1 libavahi-client3 libavahi-common-data libavahi-common3 libavahi-compat-libdnssd1 libavahi-core7 libbluetooth3 libbpf0 libcap2-bin libcrossguid0 libcups2 libcurl4 libdaemon0 libdisplay-info1
libevdev2 libfdk-aac2 libfmt7 libfstrcmp0 libgif7 libgirepository-1.0-1 libimagequant0 libinput-bin libinput10 libip6tc2 libiso9660-11 libjansson4 liblcms2-2 libldb2 liblzo2-2 libmad0 libmariadb3
libmicrohttpd12 libmnl0 libmpdec3 libmtdev1 libnetfilter-conntrack3 libnfnetlink0 libnfs13 libnftnl11 libnl-3-200 libnl-genl-3-200 libnl-route-3-200 libnspr4 libnss-mdns libnss-myhostname libnss3
libp8-platform2 libpcrecpp0v5 libpcsclite1 libpkcs11-helper1 libplist3 libpython3.9 libpython3.9-minimal libpython3.9-stdlib libsbc1 libspdlog1 libssh-4 libtag1v5-vanilla libtalloc2 libtdb1 libtevent0
libtinyxml2-8 libtinyxml2.6.2v5 libwacom-common libwacom2 libwbclient0 libwebpdemux2 libxslt1.1 libxtables12 libyajl2 mariadb-common mediacenter-addon-globalsearch-osmc mediacenter-eventclients-common-osmc
mediacenter-send-osmc mediacenter-skin-osmc mysql-common net-tools openvpn python-apt-common python-is-python3 python-pip-whl python3-dbussy python3-pexpect python3-ptyprocess python3-unidecode python3-wheel
python3.9 python3.9-minimal samba-common vero5-libcec-osmc wget wpasupplicant
Use ‘apt autoremove’ to remove them.
The following packages will be REMOVED:
armv7-network-osmc libsmbclient mediacenter-addon-osmc python3-apt python3-dbus python3-distutils python3-gi python3-ldb python3-lib2to3 python3-pil python3-pip python3-pycryptodome python3-samba
python3-setuptools python3-talloc python3-tdb samba-common-bin samba-libs vero5-device-osmc vero5-mediacenter-osmc
gcc-10-base:arm64 libc6:arm64 libcrypt1:arm64 libgcc-s1:arm64 libpython3.11-minimal libpython3.11-stdlib python3.11 python3.11-minimal
libpython3-stdlib python3 python3-minimal
3 upgraded, 8 newly installed, 20 to remove and 0 not upgraded.
Need to get 8,109 kB of archives.
After this operation, 377 MB disk space will be freed.
Do you want to continue? [Y/n] n
Very soon, we need it for Kodi v22.
Avoid backports
Fairy nuff.
Thanks for your hard work, again.
Hi Sam,
do you plan the upgrade with Kodi 22 (still in alpha) included or independently of it? As the OP said, Python 3.9 is really an issue now. Is there already a OSMC beta on Trixie I could try and use instead on the Vero V?
Trixie must come first.
No test builds yet
