TL-WN722N mounted removable storrage device (!)
Hello.
I just did a fresh install of osmc using the TP-LINK TL-WN722N and i am experiencing huge network lag between raspberry and other devices (router,Kore on iOS,Yatse on android) . And on top of that i’m getting a message on every boot that says : mounted removable storrage device. Any help is appreciated,thanks!
Check your power supply:
Thanks for your reply! I searched a little bit and I believe that it detects the wi-fi adapter as a USB storage device. I just made a clean install ,but yesterday everything worked like a charm so I don’t think that it has to do something with the power supply. I don’t have the skills to debug it though :slightly_smiling_face: . Any help would be much appreciated!
If you experience this issue on a fresh install of OSMC, I’d check your power supply.
If you only experience it with a test build, I wouldn’t worry about it as much.
So you might want to give others a chance to debug it.
Posting debug logs as described in the wiki would be a good start.
