Hi guys,
this is my first post and while I’ve seen a lot of threads on here about wifi adapters I can’t work out if I should be using a powered USB hub.
I’ve got a Pi 2 and a 2amp charger, only other usb device is a bluetooth connector for keyboard. Updated to latest version.
I don’t know how to diagnose the problem but from reading the forum it seems like this adaptor should be supported out of the box?!
I have a very cheap and rubbish wifi adaptor that works but is very slow. This is exactly the same experience I had with openelec installed before OSMC.
Would appreciate any help you can provide.
Cheers,
Andy
TP-Link TL-WN823N is supported out of the box - I have one myself and find it the best of the four adaptors I have for OSMC.
Have you tried enabling the max_usb_current option in Pi config in My OSMC and rebooting ? I think it’s a fairly power hungry adaptor and I always have that setting enabled so it’s possible it doesn’t work without it.
Also please provide the log that fzinken asked for - this will help us see whether a driver is loading.
I have a similar problem, my adapter is detected (TP link TL-WN8323N), will list my WIFI SSID on WPA2, and even claims to connect, but I cannot then SSH into the pi or even ping it’s IP.
ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
I have tried connecting the adapter directly to the pi (a model 1 B+) and through a powered hub.
I am using the latest image. I spoke to SamNazarko - he suggested it was not a driver issue.
This might be an excuse to buy yet another pi! I already have 3!
Possibly a counterfeit - I bought mine in a store in the UK not online, and mine looks exactly like the link I posted.
If it’s not a counterfeit it could be a revision using a different chipset. It’s not unheard of for a manufacturer to release a new version of an adaptor with the exact same model number on the box but in fine print it might say it is revision 2. Often this different revision has a totally different wireless chipset inside which needs different Linux drivers, which can make recommending wireless adaptors based on their advertised model number problematic…
However if you can’t find one that looks like yours on the actual TP website, then I’d guess counterfeit/clone.
