TMDB chose wrong cover art and info for movie. How do I fix it?
I have a RPi3 running OSMC. Everything scraped fine except one movie. It picked the same named movie from years ago. How to I change the file or movie scraping to pick the correct movie info and cover art?
https://www.google.com/search?q=kodi+movie+scraper+wrong+movie&rlz=1C1GIWA_enUS775US775&oq=kodi+movie+scra&aqs=chrome.2.0j69i57j0l4.5327j0j7&sourceid=chrome&ie=UTF-8
This is not an OSMC issue.
Didn’t say it was. And I’ve googled with not much luck. Just thought someone might have come across this issue and know how to fix as I haven’t been able to find a solution.
That’s strange. The simple google search I linked provides dozens of solutions.
Which aren’t working for me. Not that hard to understand. They are either not totally relevant, running older systems, etc. and the few I’ve found the seem to be helpful haven’t fixed my problem.
It actually is quite hard to understand as you have indicated in no terms at all what you have actually tried to resolve the issue. Regardless, this is not an OSMC issue and if traditional methods have failed to resolve it, you should be addressing the problem with Kodi.
Calm down tough guy. I’m new to this. Let me know what’s needed. I’ve tried refreshing, renaming movies, deleting from library and readding/scanning, etc. Basically went through multiple pages in google and within those searches looked through many posts.
Address your issue with Kodi.
We believe this is a Kodi issue or a specific Kodi function and as such you should look at addressing the issue there. We are unable to resolve your issue.
If you haven’t found it already, take a look here: http://kodi.wiki/view/Incorrect_and_missing_videos
Thank you dillthedog. I’ll check that out. I looked over some other wikis, but not I don’t believe this one.
