The total uptime is always reseted, no matter if i shutdown the rpi2 or reboot. So on my rpi2 total uptime is always reset to 0 minutes.
If i let the rpi run on for 8h it shows system uptime=8h and total uptime=8h . But after restart system uptime and total uptime it reverts to 0 minutes.
As said by @Smurphy this is expected behaviour. This variable is reset on every reboot…
Total uptime/system uptime is the time since last boot/reboot. AFAIK there is no way of finding out how long a system over it’s total lifetime has been running which I assume you are expecting.
Guys sorry but both of you are wrong. “Total Uptime” is a value that is store in guisettings.xml and therefore is not supose to be reseted by a reboot.
So if that is happening “again” it is a topic that needs to looked into.
System uptime isn’t written when Kodi exits anymore. This is intentional and related to an issue that was quite annoying last year: Skin changes lost after a reboot.
I’ve made some changes to how and when settings are written to guisettings.xml in Kodi. As a consequence, we don’t bother writing the uptime when Kodi is exiting. See
If we revert this patch; then uptime will be saved, but there is a great potential for settings to be lost (skin change is most common symptom) when rebooting; particularly if Kodi hangs due to a bad / poorly written add-on.
I had the problem since version 17.4 17.5 Debian Jessie and I was waiting for the stretch version maybe solve the problem but it persists. in Kodi 18 debian version Jessie did not have the problem but in Kodi 18 debian stretch I find the problem
