This isn’t so much about technical issues, but rather usability.
I am using the latest OSMC, A Pi 1 B and a big 22" AOC touchscreen I bought a few years ago.
Touch control is recognized and works like a charm and the osmc standard skin isn’t so bad for touch - at least basically, in fact, it is far from perfect.
I am having quite a hard time navigating through the menu and I don’t get why.
On the main screen it is all tapping and everything is fine.
In the deeper menus, e.g. media, addons & stuff, I can drag and scroll but my click focus is in the middle of the screen. So tapping an item on the list does not work - I have to scroll until it is highlighted (=yellow) and then tap - and hope I don’t issue a drag command.
By trying and some luck I found that I can access the main menu by a long touch.
But If I do this - how can I go back to my playing video? With a keyboard attached it is the “Tab” button - yet there is no way to get back for pure touch control.
Another thing: Volume control? Without keyboard? Nope.
Any hints? It basically works well but there are many things that could go better.
