I hooked the raspberry to lan, here is the dmesg with wifi encryption enable
osmc@osmc:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.13-1-osmc (root@vero) (gcc version 4.9.2 (Rasp
bian 4.9.2-10) ) #1 PREEMPT Sun May 17 15:58:48 UTC 2015
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr
=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruc
tion cache
[ 0.000000] Machine model: Raspberry Pi Model B
[ 0.000000] cma: Reserved 8 MiB at 0x16800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 94208
[ 0.000000] free_area_init_node: node 0, pgdat c0992c6c, node_mem_map d651400
0
[ 0.000000] Normal zone: 736 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 94208 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag
es: 93472
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1360
bcm2708_fb.fbheight=768 bcm2708.boardrev=0x100000f bcm2708.serial=0xc0fced8d sms
c95xx.macaddr=B8:27:EB:FC:ED:8D bcm2708_fb.fbswap=1 sdhci-bcm2708.emmc_clock_fre
q=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 root=/dev/mmc
blk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp1
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 354636K/376832K available (7289K kernel code, 356K rwdata
, 1828K rodata, 328K init, 726K bss, 22196K reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
vmalloc : 0xd7800000 - 0xff000000 ( 632 MB)
lowmem : 0xc0000000 - 0xd7000000 ( 368 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc08ef7b0 (9118 kB)
.init : 0xc08f0000 - 0xc0942000 ( 328 kB)
.data : 0xc0942000 - 0xc099b26c ( 357 kB)
.bss : 0xc099b26c - 0xc0a50b28 ( 727 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:522
[ 0.000023] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2
147483648000ns
[ 0.000069] Switching to timer-based delay loop, resolution 1000ns
[ 0.000340] Console: colour dummy device 80x30
[ 0.000544] console [tty0] enabled
[ 0.000567] Calibrating delay loop (skipped), value calculated using timer fr
equency… 2.00 BogoMIPS (lpj=10000)
[ 0.000592] pid_max: default: 32768 minimum: 301
[ 0.000938] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000965] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001918] Initializing cgroup subsys memory
[ 0.001969] Initializing cgroup subsys devices
[ 0.001997] Initializing cgroup subsys freezer
[ 0.002022] Initializing cgroup subsys net_cls
[ 0.002042] Initializing cgroup subsys blkio
[ 0.002127] CPU: Testing write buffer coherency: ok
[ 0.002201] ftrace: allocating 17808 entries in 53 pages
[ 0.094595] Setting up static identity map for 0x6baa48 - 0x6baaa4
[ 0.097292] devtmpfs: initialized
[ 0.113678] VFP support v0.3: implementor 41 architecture 1 part 20 variant b
rev 5
[ 0.116882] pinctrl core: initialized pinctrl subsystem
[ 0.119380] NET: Registered protocol family 16
[ 0.124551] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.154384] cpuidle: using governor ladder
[ 0.184436] cpuidle: using governor menu
[ 0.184634] bcm2708.uart_clock = 3000000
[ 0.187696] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.187723] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.187762] mailbox: Broadcom VideoCore Mailbox driver
[ 0.187894] bcm2708_vcio: mailbox at f200b880
[ 0.188314] bcm_power: Broadcom power driver
[ 0.188339] bcm_power_open() -> 0
[ 0.188351] bcm_power_request(0, 8)
[ 0.689044] bcm_mailbox_read -> 00000080, 0
[ 0.689063] bcm_power_request -> 0
[ 0.689227] Serial: AMBA PL011 UART driver
[ 0.689446] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a
PL011 rev3
[ 0.757687] SCSI subsystem initialized
[ 0.757984] usbcore: registered new interface driver usbfs
[ 0.758107] usbcore: registered new interface driver hub
[ 0.758276] usbcore: registered new device driver usb
[ 0.760050] Switched to clocksource stc
[ 0.786948] FS-Cache: Loaded
[ 0.787322] CacheFiles: Loaded
[ 0.802747] NET: Registered protocol family 2
[ 0.804117] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.804222] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.804323] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.804408] TCP: reno registered
[ 0.804445] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.804479] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.804792] NET: Registered protocol family 1
[ 0.805420] RPC: Registered named UNIX socket transport module.
[ 0.805450] RPC: Registered udp transport module.
[ 0.805462] RPC: Registered tcp transport module.
[ 0.805472] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.805961] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters ava
ilable
[ 0.806212] bcm2708_dma: DMA manager at f2007000
[ 0.806398] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000
000(512 MiB)
[ 0.807945] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.808080] audit: initializing netlink subsys (disabled)
[ 0.808179] audit: type=2000 audit(0.740:1): initialized
[ 0.823470] VFS: Disk quotas dquot_6.5.2
[ 0.823842] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.826586] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.828319] NFS: Registering the id_resolver key type
[ 0.828438] Key type id_resolver registered
[ 0.828456] Key type id_legacy registered
[ 0.829787] msgmni has been set to 708
[ 0.833034] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
52)
[ 0.833414] io scheduler noop registered
[ 0.834034] io scheduler bfq registered (default)
[ 0.834052] BFQ I/O-scheduler version: v7r7
[ 0.836374] BCM2708FB: allocated DMA memory 56c00000
[ 0.836447] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 0.851017] Console: switching to colour frame buffer device 170x48
[ 0.863292] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driv
er
[ 0.863723] uart-pl011 dev:f1: no DMA platform data
[ 0.864445] vc-cma: Videocore CMA driver
[ 0.864469] vc-cma: vc_cma_base = 0x00000000
[ 0.864482] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.864493] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.877472] brd: module loaded
[ 0.884590] loop: module loaded
[ 0.885512] vchiq: vchiq_init_state: slot_zero = 0xd6c80000, is_master = 0
[ 0.886744] Loading iSCSI transport class v2.0-870.
[ 0.888180] usbcore: registered new interface driver smsc95xx
[ 0.888306] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.088595] Core Release: 2.80a
[ 1.088634] Setting default values for core params
[ 1.088664] Finished setting default values for core params
[ 1.288835] Using Buffer DMA mode
[ 1.288865] Periodic Transfer Interrupt Enhancement - disabled
[ 1.288877] Multiprocessor Interrupt Enhancement - disabled
[ 1.288890] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.288907] Dedicated Tx FIFOs mode
[ 1.289347] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xd6c
14000 dma = 0x56c14000 len=9024
[ 1.289386] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.289415] dwc_otg: Microframe scheduler enabled
[ 1.289486] WARN::hcd_init_fiq:412: FIQ on core 0 at 0xc04fd81c
[ 1.289506] WARN::hcd_init_fiq:413: FIQ ASM at 0xc04fdaf8 length 36
[ 1.289538] WARN::hcd_init_fiq:438: MPHI regs_base at 0xd7806000
[ 1.289572] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.289632] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number
1
[ 1.289703] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.289745] Init: Port Power? op_state=1
[ 1.289757] Init: Power Port (0)
[ 1.290252] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.290280] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=
1
[ 1.290297] usb usb1: Product: DWC OTG Controller
[ 1.290313] usb usb1: Manufacturer: Linux 3.18.13-1-osmc dwc_otg_hcd
[ 1.290329] usb usb1: SerialNumber: bcm2708_usb
[ 1.291437] hub 1-0:1.0: USB hub found
[ 1.291541] hub 1-0:1.0: 1 port detected
[ 1.292173] dwc_otg: FIQ enabled
[ 1.292195] dwc_otg: NAK holdoff enabled
[ 1.292207] dwc_otg: FIQ split-transaction FSM enabled
[ 1.292266] Module dwc_common_port init
[ 1.292809] usbcore: registered new interface driver usb-storage
[ 1.293264] mousedev: PS/2 mouse device common for all mice
[ 1.294537] bcm2835-cpufreq: min=700000 max=850000
[ 1.294898] sdhci: Secure Digital Host Controller Interface driver
[ 1.294919] sdhci: Copyright© Pierre Ossman
[ 1.295185] DMA channels allocated for the MMC driver
[ 1.330116] Load BCM2835 MMC driver
[ 1.330477] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.331045] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.331248] hidraw: raw HID events driver © Jiri Kosina
[ 1.331563] usbcore: registered new interface driver usbhid
[ 1.331582] usbhid: USB HID core driver
[ 1.331980] TCP: cubic registered
[ 1.332011] Initializing XFRM netlink socket
[ 1.332065] NET: Registered protocol family 17
[ 1.332297] Key type dns_resolver registered
[ 1.333637] registered taskstats version 1
[ 1.333948] vc-sm: Videocore shared memory driver
[ 1.333976] [vc_sm_connected_init]: start
[ 1.339448] [vc_sm_connected_init]: end - returning 0
[ 1.348443] Waiting for root device /dev/mmcblk0p2…
[ 1.377675] mmc0: host does not support reading read-only switch, assuming wr
ite-enable
[ 1.379954] mmc0: new high speed SDHC card at address 59b4
[ 1.380835] mmcblk0: mmc0:59b4 SDU1 14.7 GiB
[ 1.382746] mmcblk0: p1 p2
[ 1.453847] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst
em
[ 1.453888] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.490338] Indeed it is in host mode hprt0 = 00021501
[ 1.670273] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.670495] Indeed it is in host mode hprt0 = 00001101
[ 1.870618] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 1.870656] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.871889] hub 1-1:1.0: USB hub found
[ 1.872085] hub 1-1:1.0: 3 ports detected
[ 1.984875] EXT4-fs (mmcblk0p2): recovery complete
[ 1.992275] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O
pts: (null)
[ 1.992396] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.998667] devtmpfs: mounted
[ 2.000010] Freeing unused kernel memory: 328K (c08f0000 - c0942000)
[ 2.150353] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.250717] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.250752] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber
=0
[ 2.254053] smsc95xx v1.0.4
[ 2.316456] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-bcm2708_usb-1
.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:fc:ed:8d
[ 2.410378] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 2.527538] usb 1-1.2: New USB device found, idVendor=148f, idProduct=5572
[ 2.527576] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber
=3
[ 2.527592] usb 1-1.2: Product: 802.11 n WLAN
[ 2.527608] usb 1-1.2: Manufacturer: Ralink
[ 2.527625] usb 1-1.2: SerialNumber: 1.0
[ 2.610377] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 2.712103] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0610
[ 2.712144] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber
=0
[ 2.712163] usb 1-1.3: Product: USB2.0 Hub
[ 2.713554] hub 1-1.3:1.0: USB hub found
[ 2.714052] hub 1-1.3:1.0: 4 ports detected
[ 4.225964] random: systemd urandom read with 85 bits of entropy available
[ 4.311577] NET: Registered protocol family 10
[ 5.047707] systemd[1]: Cannot add dependency job for unit display-manager.se
rvice, ignoring: Unit display-manager.service failed to load: No such file or di
rectory.
[ 5.048430] systemd[1]: Found ordering cycle on basic.target/start
[ 5.048498] systemd[1]: Found dependency on sysinit.target/start
[ 5.048560] systemd[1]: Found dependency on kbd.service/start
[ 5.048621] systemd[1]: Found dependency on remote-fs.target/start
[ 5.048671] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 5.048722] systemd[1]: Found dependency on connman.service/start
[ 5.048769] systemd[1]: Found dependency on basic.target/start
[ 5.048819] systemd[1]: Breaking ordering cycle by deleting job kbd.service/s
tart
[ 5.048875] systemd[1]: Job kbd.service/start deleted to break ordering cycle
starting with basic.target/start
[ 5.259382] fuse init (API version 7.23)
[ 5.550976] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.460613] systemd-udevd[103]: starting version 215
[ 7.668242] cfg80211: Calling CRDA to update world regulatory domain
[ 8.370519] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[ 8.486194] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5592, rev 0222 d
etected
[ 8.537337] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data
may be corrupt. Please run fsck.
[ 8.780594] random: nonblocking pool is initialized
[ 9.030524] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 000f detected
[ 9.168113] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
[ 9.177930] usbcore: registered new interface driver rt2800usb
[ 9.734562] cfg80211: World regulatory domain updated:
[ 9.734609] cfg80211: DFS Master region: unset
[ 9.734627] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai
n, max_eirp), (dfs_cac_time)
[ 9.734649] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 m
Bm), (N/A)
[ 9.734665] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 m
Bm), (N/A)
[ 9.734680] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 m
Bm), (N/A)
[ 9.734698] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AU
TO), (N/A, 2000 mBm), (N/A)
[ 9.734715] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AU
TO), (N/A, 2000 mBm), (0 s)
[ 9.734733] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000
mBm), (0 s)
[ 9.734749] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 m
Bm), (N/A)
[ 9.734764] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0
mBm), (N/A)
[ 10.899825] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 12.622785] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 12.623620] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.995308] systemd-journald[83]: Received request to flush runtime journal f
rom PID 1
[ 13.592502] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmwa
re file ‘rt2870.bin’
[ 13.681920] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detec
ted - version: 0.29
[ 14.164396] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 20.854003] Console: switching to colour dummy device 80x30
[ 1421.899606] wlan0: authenticate with dc:fb:02:e7:d7:75
[ 1421.978218] wlan0: send auth to dc:fb:02:e7:d7:75 (try 1/3)
[ 1421.979793] wlan0: authenticated
[ 1421.992234] wlan0: associate with dc:fb:02:e7:d7:75 (try 1/3)
[ 1421.998831] wlan0: RX AssocResp from dc:fb:02:e7:d7:75 (capab=0x1001 status=0
aid=1)
[ 1422.012783] wlan0: associated
[ 1422.012973] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
osmc@osmc:~$
