Is it possible to transfer an SD card from a Raspberry Pi 1 B+ to the Raspberry Pi 2? On Raspbian a
sudo apt-get update && sudo apt-get dist-upgrade
would allow you to transfer the card between hardware. Is this possible on OSMC?
Many thanks for hours you spend coding.
