I just updated the vero 4k with the May update and after that I get denied access when I try to start a torrent with the built in transmission app from the App Store. It worked fine before and I haven’t done any changes so it must be the update. I have reboot, taken out the USB disk (ext3). Stopped the transmission deamon, uninstalled reboot and reinstalled but nothing works. I read the various thread about permission issues but could really find one related to my issue. Please help!
Thanks,
Fred
Sorry here is the log. the log contains my tries to remove, reinstall etc.
ps how can i remove the log later on? wouldnt want it floating around internet
Thanks,
Fred
Looks like a transmission configuration typo:
Couldn't create "/Media/9668a741-4d40-4d56-bd04-c37ebed237b7/media/TV Series"
It should be /media with a small m.
It might not have been the original issue, but its currently causing a problem.
Hiya,
Thank you very much! Yes it solved the problem, very strange indeed it did not had any issues before.
Anyway thank you very much again!
