Hello! I recently purchased the Raspberry Pi 3, and installed OSMC. I love how the OS works, and for the most part it works perfectly fine, save for two things (in my case).
Transmission search sources: When I first loaded up the Transmission add-on, I noticed that a couple of my fav sources weren’t included - so I went hunting. I came across the Transmission XBMC Repo. I copied across the resource folder into the
script.transmissionadd-on folder, and the sources showed up fine. However, the repo itself had some out of date URIs, so I’ve made a pull request to remedy that. The weird thing is, sometimes it works, sometimes it doesn’t. When it doesn’t work, I get the dreadedcould not connect to search sitemessage. Has anyone else experienced this? -
Secondly, scraping any movies or TV shows does not work. I’ve set up my TV shows and Movies to reflect the expected formats and folder structures as shown here. Is there a way to test that the scraping function works at all? Would I find more clues in the logs?
