Hello everyone!
I have been install the osmc in raspberry 4 with all services but transimission doesn’t working when i open the remote-gui from the windows system. in the same time when i open from the linux os system( ubuntu) working fine.
What could be happening with transmission remote gui in windows? Any idea?
Perhaps there is a mismatch between the version of the tool you are using and the version of Transmission we distribute.
If the web interface works as expected, then it’s not an OSMC issue.
Hello!
Thank a lot for the help but i solved this problem a days ago! The problem was my wifi router have been break and raspberry didn’t connect to internet.
