The Transmission Folder changes to default /home/ location when I pull out a mouse etc from the usb, Is this normal?
Rpi 2
OSMC STABLE Release
Transmission via app store
Rpi 2
OSMC STABLE Release
Seems like it must be something else that to blame here… if you make changes in the transmission config file “settings.json”, you have to stop transmission before you change anything and then make your changes and start it.
Have you made any changes to transmission config?
-H
Nope only used the web interface to limit upload rates.
Can be a power issue, if possible can you try with another PSU? or a powered USB hub.
-H
Already using a power cable, but if it happens again will inform here.
