I mount my Harddrive in /mnt/data.
I am able to access my Harddrive from ssh.
Then i unmounted the drive.
I changed owner of data to osmc and gave 777 to /mnt/data.
I have installed Transmission from App Store and from the web interface i added the torrent file.
But i am getting the Error saying it is unable to access the folder.
What does ls -l of /mnt/data look like when the drive is mounted? I can see you chmodded /mnt/data but that was unmourned, what do the subdirectories look like?
Ohh forgot that OSMC has a transmission package but make sure that it has recursive permission in that folder so that new folders get the same permissions.
usually dont rely on custom packages when i set up my stuff
I guess this is what is causing issues.
After I unmounted the HDD, I changed the ownership and permissions.
But when I mount the HDD again. It is getting changed.
OK I was able to make it persistent by adding a record in /etc/fstab.
And now it is showing properly owner and permissions.
Still I am not able to write anything.
I guess either your filesystem is corrupted (the input/output error indicates that) or you have a wrong fstab line (which should not be necessary anyhow if everything is running normal automount will mount it as osmc/osmc.
Check/post your dmesg/journal output also post your fstab
osmc@osmc:~$ sudo umount /mnt/data/
osmc@osmc:~$ sudo fsck.vfat /dev/sdb1
fsck.fat 3.0.27 (2014-11-12)
0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corru pt.
1) Remove dirty bit
2) No action
? 1
There are differences between boot sector and its backup.
This is mostly harmless. Differences: (offset:original/backup)
65:02/00
1) Copy original to backup
2) Copy backup to original
3) No action
? 3
/FOUND.000
Contains a free cluster (1410). Assuming EOF.
/DSLR Pics/Ernakulam pics/DSC_0232.JPG
Contains a free cluster (453469). Assuming EOF.
File size is 8223095 bytes, cluster chain length is 0 bytes.
Truncating file to 0 bytes.
Reclaimed 141 unused clusters (4620288 bytes).
Free cluster summary wrong (28404809 vs. really 28404950)
1) Correct
2) Don't correct
? 1
Leaving filesystem unchanged.
/dev/sdb1: 81120 files, 2111349/30516299 clusters
0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
1) Remove dirty bit
2) No action
? 1
65:02/00
3) No action
? 3
/FOUND.000
1) Correct
2) Don't correct
? 2
But after i mounted the drive, i am still seeing the same error. Did i do anything wrong? Or if i just deleted that one pic which in fsck will this issue be solved ?
Well my gut feeling is something serious wrong with that drive. Is it getting enough power? How is it powered?
Suggest to backup all files and format the drive. Or maybe connect to a windows PC and check what that says.
@fzinken sorry for the late reply… i got struck with some work. I connected the drive to Windows and fixed the errors. There were some boot error.
Now Transmission is able to access the drive. Thanks for your help.
