After getting a VPN-service for our home computers and therafter trying to getting it to run on the Raspberry Pi B+ (OSMC 2017.12-1) i’ve run into a number of problems.
I searched the forums and the web for guides on the VPN and i think i have it up and running as it should. But when I try to download anything via Transmission I get errors after 2-3 minutes of downloading.
“Unable to save resume file: Permission denied”
I resume the download and the same error appears after 2-3 minutes.
*More searching on the forums and the web…
I found alot of information on different issues with permissions and so on. I mucked about with that for 2 days now and nothing seems to work or getting me closer to a solution.
Could my VPN cause this issues? And where can i find information on how to fix it?
How/where can i check if the permissions for Tranmission/users is the issue?
Any help or tips to get everything up and running as before?
I’m a beginner when it comes to this kind of stuff but i’m fairly competent with computers in general and somewhat decent in figuring out stuff as i go along. But this time i am lost.
I tried to upload the logs but I get this error message:
Exception Details:
File “/usr/bin/grab-logs”, line 792, in dispatch_logs
raise ValueError(‘Upload Returned Empty String’)
ValueError: Upload Returned Empty String
Failed to upload log files, copying to /boot instead. (Unable to verify)
Absolutely no idea why there would be 2 VPN tunnels. Good/bad? Must have been in one of the guides i went through in my efforts in getting the VPN to work.
Yes, thats not right. I went through the guides i followed and in one of them there was references to settings/config for PIA. Must have missed that.
But i’m using OVPN and it’s working great on two other computers here at home.
