I finished setting up my Rpi 3 B+ with OSMC. I got everything working great except transmission. I’ve tried with multiple torrents varying in size from different trackers. The same thing happens. It connects to peers, speed jumps to 2-3 MB/s, stays there for a few seconds, then it throttles down to speeds in the kB/s range, sometimes to 0. Stays there a few seconds, jumps back up to 3 MB/s. It makes downloading anything a hassle.
I’ve checked my transmission settings, the speed is not limited, no maximum speed, no nothing. I tried wired connection&wireless, does the same thing. I tried operating it on a single port(no random port) and opened that port on my router. Did not influence it one bit. Nothing changes. I am downloading to a USB Kingston DataTraveler DT106/64GB stick that was formatted to Ext4.
My internet connection is really good, I have no limitations from my ISP and any torrent downoalds without any issues on my PC.
Wired right now, tried wi-fi also and the same issue occurs. The stick is directly connected to the Raspberry’s USB port. Wouldn’t using a hub slow things down even more? Directly seems like the better choice, no? Thanks
Ah, ok. Hadn’t thought about the power draw… But wouldn’t the hub be connected to the Rpi and in the end draw the same amount of power? I’m sorry if this is a stupid question
Oh, ok, I see. Didn’t even know those were a thing. Ok, might try one of those. I just tried downloading directly to the OS SD card. The same thing happens…
Yeah, it’s definitely a power problem. Tried transferring files through SAMBA from my PC. The same thing happens with the speed. Thank you for pointing me in the right direction!
Did you try the dd test that I suggested? That will help narrow down the problem. The test you did via SMB still could be another problem, like networking.
Will be trying this today, for now I am locked out of OSMC while trying to set up UFW and now I can’t SSH. Can’t even access the console locally with a keyboard. I tried Exit - Wait for splashscreen - Hit Esc. But no splashscreen appears, it just boots directly into OSMC after showing a black screen for 30 sec. So think I’ll have to format and reinstall…
