Tried update getting this message
Error installing ssh-app-osmc
Can you upload logs via My OSMC?
I take it you got to
Log uploader
Upload selected logs now
As I’ve done that
Then get this
URL:https://paste.osmc.tv/ititelsges
What is the output of
ls -lah /etc/ssh/sshd_config.distributed
I don’t know what that is
Connect to the command line (see below) and run that command and let us know what is says. There seems to be a problem with your config files.
Alternatively you could try to uninstall and reinstall ssh-app.
Details regarding how to access the command line interface can be found here on our Wiki: https://osmc.tv/wiki/general/accessing-the-command-line/
Just tried reinstalling ssh app
Operations successfully completed
OK, then I assume update should also work now without error
That seems ok
But get this after reboot
Add-on couldn’t be loaded
An unknown error has occurred
Would need a debug enabled log for that.
These are not looking good:
ERROR: SQL: [MyVideos116.db] SQLite error SQLITE_IOERR_READ (disk I/O error) 2019-08-07 15:57:59.565 T:3939496672 DEBUG: CAddonCallbacksAddon - GetAddonSetting - add-on 'Enigma2 Client' requests setting '__addonpath__' 2019-08-07 15:57:59.565 T:3939496672 ERROR: Create - Error creating X����/��
You could try a full reinstall but suggest to then keep monitoring it after the reinstall
Been getting them error messages since first week of owning
How to do a full reinstall?
While maybe not as efficient as a reinstall you could first try with a clean Kodi setup
mv .kodi .kodi.save
And I use putty for that?
Yes. It looks like the issue might just be with your Kodi setup, and therefore a complete system reinstall may not be necessary.
yes
Did that
After reboot no error messages
So I presume for now all is well
