Ok so you were right the sd card just was not pushed in all the way but once I did that the green light started flashing and I now have an image on the screen where it says usb install with a 60 sec countdown to remove device before data loss. Then after the countdown it goes to a screen where it says “install failed: can’t mount root”
Possibly a defective SD card, possibly it got corrupted with not being pushed in all the way. I would just redo the image in the Windows installer and try again. If that doesn’t work try another SD card.
Check the checksum of the image you downloaded before trying again.
it now works thank you!
