I had an old Pi 1 laying around and set up OSMC on it to check it out. Things worked fine, albeit a little slow. So I ordered a new Pi 3 and tried to install via an 8GB micro SD card. When I boot the Pi 3, it says it is formatting, then goes to say it is installing and gets about 3/4 done and then nothing. I’ve had it running for about 4 hours and didn’t complete the install. Is there any way I can look at a log file or something to see what’s going on?
Try another card
Check your PSU
Yup, used a different card which was 16GB and its working great. Thanks!
