I have a bunch of 3d mvc movies. I actually rarely would try and skip through a movie, but for testing Vero V, I did. So, what happens is when skipping forward with the remote, say hitting OK then fast foward, the machine eventually completely locks up, non responsive, can’t even ssh in. Have to remove power. In this case, this is with staging osmc version which I loaded to get Pluto TV Pvr.
So, understand I enabled debug logging, then rebooted twice, then did various skip forward and back commands and then fast forward, and it locked up. Hopefully debug logging written to disk as I had to remove power and boot back up to upload logs. The link I got was paste.osmc.tv/cudoniruge
This happens virtually (but not always) every time I use fast forward. Mediainfo:
I should point out I am playing the 3D movies via Emby for Kodi Nextgen if that makes any difference. They do play fine without skipping around in the movie.
You might find this with ISOs because of the nature of how the container is structured; although some improvements to libbluray that we have in the staging repository might mitigate this somewhat.
Do you experience this with MKV?
It would also be good to know if you experience this with local playback
This is 3d mvc mkv created with makemkv from bluray and with staging repo version. My main use of the Vero V is probably not the same as anyone else, it’s to play 3d mvc mkv content. I will try locally playing it tonight. Actually, I can’t play locally as the internal storage isn’t big enough but I can play via nfs share.
My guess is it’s a Kodi bug. I downloaded the Kodi remote from IOS app store and scrubbing on the timeline works every time, no lockups. Scrubbing is actually better anyway than fast forward/rewind.
Ah, there’s 2 links. I see the top one now. Unfortunately no idea how to recover that link, is there a way from Vero to get it back?
If not, will have to wait a month, leaving the country. While I can converse, no way to get logs really unless they are stored somewhere and ssh can retrieve them from that time.
I guess that’s the downside of using my osmc method, didn’t see a way to copy and paste the link, must have made a typo.
Just popping in to say I have been experiencing the same exact behavior. Fully locks up when seeking or FF’ing around in 3Ds. Happens with ISOs and mkvs. Requires unplug to restart.
We have some MVC improvements that might improve stability if you’d like to test them. We will make them part of the next available update, but you can test them now.
Run the following command to add the staging repository: echo 'deb http://apt.osmc.tv bullseye-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command: sudo rm /etc/apt/sources.list.d/osmc-devel.list.
@sam_nazarko I fiddled around with the beta and I haven’t experienced this issue since. Jumping around and seeking in 3D MVC is seamless! Performance seems parity with 2D. Also idk if this is just placebo but exiting from 3D MVC playback back to Kodi interface seems faster now too.
