So, running Vero V, 2023.08-1, updated today for latest stuff. I have some 3d top and bottom videos. The playback setting for 3d is set to “ask me”. So, I try and play one. I click on the movie and it brings up the “select playback mode” screen, and, I decide I clicked the wrong movie so select cancel. It doesn’t cancel, it starts the movie but in a paused state. Hitting the return button on the remote doesn’t go back either, it stays on the screen. You actually can’t get out of the playback selection, even home stays on the screen. You have to start the movie. This is problem 1.
Problem 2 is I get garbage on the screen for top and bottom to my Epson projector. See image. That being said, all 3d mvc movies seem to play fine, it’s just the top and bottom formats that do not. Note that I can play the movies in vlc, emby, etc and they play like top and bottom and switching the projector to top and bottom mode then shows them in 3d just fine. But this doesn’t work here.
reproduce the issue
Again, this is a Vero V I just got and updated to current software. there are no peripherals attached. Happens on every top and bottom 3d movie I have which were all created by bd3d2mk3d utility. They all play on all other clients I have including Emby.
