I have my RPi 2 running osmc with no problem.
I also have hyperion installed (using SPI bus) which works fine.
My problem comes with the Razberry (Z-Wave) addin card which use the serial port of the RPi 2.
I cannot connect to the server using ttyAMA0.
My question is : how can I see if ttyAMA0 is already configured/used by another process ? and if so, how can I free it ?
Thank you for your help
I’m unsure from what you post whether you can SSH to the RPi - but if you can, then
ls -l /dev |grep ttyAMA will show if it exists/is configured
ps -ef |grep tty will show some types of use (eg getty)
As to freeing it, it depends what has created or is using it - you may have to delve into the startup scripts to find it, and freeing it may compromise the system.
Derek
I haven’t configured ttyAMA0 in OSMC as it doesn’t make much sense to do this. systemd may have done something new fangled, so I’d check for the existence of:
/etc/systemd/system/getty.target.wants/getty@ttyAMA0.service
I’d check you can run the following command
echo test | sudo tee /dev/ttyAMA0
I’m not sure what that card does, but it goes without saying you’ll need permission to access /dev/ttyAMA0 (and its currently owned by root). I’d suggest:
sudo chown osmc:osmc /dev/ttyAMA0
- if your card now works, you’ll need to set up a udev rule to fix the ownership of the device on boot
S
Thank you for your help !
I think that you’re right and the ttyAMA0 is not the problem. here is my results :
osmc@osmc:/etc/systemd/system$ ls
bluetooth.target.wants
hwclock.service.d
multi-user.target.wants
sockets.target.wantsdbus-org.bluez.service
sshd.servicedbus-org.freedesktop.Avahi.service
serial-getty@ttymxc0.servic.service sysinit.target.wantsfake-
serial-getty@ttymxc0.service
osmc@osmc:/etc/systemd/system$ echo test | sudo tee /dev/ttyAMA0
test
osmc@osmc:/etc/systemd/system$ sudo chown osmc:osmc /dev/ttyAMA0
osmc@osmc:/etc/systemd/system$ ls -la /dev/ | grep ttyAMA0
crw-rw---- 1 osmc osmc 204, 64 Apr 3 10:41 ttyAMA0
I saw a problem when manually start the serveur :
osmc@osmc: /opt/z-way-server$ sudo /etc/init.d/z-way-server stop
Stopping z-way-server: done.
osmc@osmc: /opt/z-way-server$ cd /opt/z-way-server
osmc@osmc: /opt/z-way-server$ sudo ./z-way-server
./z-way-server: error while loading shared libraries: libzcommons.so: cannot open shared object file: No such file or directory
But I’m not able to apt-get this Lib. Any idear ?
Problem solved by creating a link to the library :
sudo ln -s /usr/lib/arm-linux-gnueabihf/libarchive.so.13 /usr/lib/arm-linux-gnueabihf/libarch ive.so.12
