I’m trying to figure out why some files are recognized by TV as 10 bit when most are not.
Here is the file played back correctly:
General
Unique ID : 179768350720378371925034052307682204296 (0x873E1FFE11E218779845D5E9E7621A88)
Complete name : The_World_in_HDR_in_4K_HDR10.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 308 MiB
Duration : 2mn 34s
Overall bit rate : 16.7 Mbps
Movie name : The World in HDR in 4K - Demo-UHD3D.com
Encoded date : UTC 2017-04-24 13:38:07
Writing application : mkvmerge v11.0.0 (‘Alive’) 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
DURATION : 00:02:34.569000000
NUMBER_OF_FRAMES : 7450
NUMBER_OF_BYTES : 2116797
_STATISTICS_WRITING_APP : mkvmerge v11.0.0 (‘Alive’) 64bit
_STATISTICS_WRITING_DATE_UTC : 2017-04-24 13:38:07
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Video
Format : HEVC
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2mn 34s
Bit rate : 16.3 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 fps
Bits/(Pixel*Frame) : 0.033
Stream size : 300 MiB (97%)
Default : Yes
Forced : No
Audio
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Duration : 2mn 34s
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 2.36 MiB (1%)
Language : English
Default : Yes
Forced : No
Writing application : Google
Here is the one that plays as SDR:
General
Unique ID : 236558978440196851327403649777541729215 (0xB1F79A1DED887FAAAFA15FA5E6A64BBF)
Complete name : ./jellyfish-140-mbps-4k-uhd-hevc-10bit.mkv
Format : Matroska
File size : 503 MiB
Duration : 30s 293ms
Overall bit rate : 139 Mbps
Encoded date : UTC 2016-02-06 04:59:45
Writing application : mkvmerge v8.6.1 (‘Flying’) 64bit
Writing library : Lavf56.3.100
DURATION : 00:00:30.293000000
NUMBER_OF_FRAMES : 36352
NUMBER_OF_BYTES : 10303316
_STATISTICS_WRITING_APP : mkvmerge v8.6.1 (‘Flying’) 64bit
_STATISTICS_WRITING_DATE_UTC : 2016-02-06 04:59:45
Video
Format : HEVC
Format profile : Main 10@L5.1
Duration : 30s 297ms
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Writing library : x265 1.8+190-75d1c62d8f0c:[Windows][MSVC 1700][64 bit] 10bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=25 / scenecut=40 / rc-lookahead=20 / lookahead-slices=8 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.30 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=2 / pass / bitrate=146000 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Encoded date : UTC 2016-02-06 04:56:11
HANDLER_NAME : hevc@GPAC0.5.2-DEV-rev565-g71748d7-ab-suite
DURATION : 00:00:30.030000000
NUMBER_OF_FRAMES : 900
NUMBER_OF_BYTES : 517356145
_STATISTICS_WRITING_APP : mkvmerge v8.6.1 ('Flying') 64bit
Audio
Format : TrueHD
Codec ID : A_TRUEHD
Maximum bit rate : 4 851 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossless
Delay relative to video : -67ms
Default : Yes
Forced : No
As far as I can tell both have true 10 bit encoded. Is there a way to make files like second one to play in HDR?
EDID:
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
