Here’s what happens with bluetoothctl:
osmc@osmc:~$ bluetoothctl
[NEW] Controller B8:27:EB:91:23:AC osmc [default]
[NEW] Device 88:C6:26:9C:F6:D4 UE BOOM 2
[bluetooth]# agent on
Agent registered
[bluetooth]# trust 88:C6:26:9C:F6:D4
[CHG] Device 88:C6:26:9C:F6:D4 Trusted: yes
Changing 88:C6:26:9C:F6:D4 trust succeeded
[bluetooth]# pair 88:C6:26:9C:F6:D4
Attempting to pair with 88:C6:26:9C:F6:D4
[CHG] Device 88:C6:26:9C:F6:D4 Connected: yes
[CHG] Device 88:C6:26:9C:F6:D4 Paired: yes
Pairing successful
[CHG] Device 88:C6:26:9C:F6:D4 Connected: no
[bluetooth]# connect 88:C6:26:9C:F6:D4
Attempting to connect to 88:C6:26:9C:F6:D4
Failed to connect: org.bluez.Error.Failed
[bluetooth]#
Could anyone suggest what might be the next step to getting this thing connected via bluetooth? Thanks!
Thanks for this! I’m using the built-in Bluetooth on the Pi 3. But anyway - we’re getting somewhere! I ran apt-get update and apt-get dist-upgrade and the command above. Retried connecting with the following results:
Agent registered
[bluetooth]# scan on
Discovery started
[CHG] Controller 60:57:18:C3:4C:C1 Discovering: yes
[CHG] Device 88:C6:26:9C:F6:D4 UUIDs: 00000000-deca-fade-deca-deafdecacaff
[CHG] Device 88:C6:26:9C:F6:D4 UUIDs: 00001101-0000-1000-8000-00805f9b34fb
[CHG] Device 88:C6:26:9C:F6:D4 UUIDs: 0000110a-0000-1000-8000-00805f9b34fb
[CHG] Device 88:C6:26:9C:F6:D4 UUIDs: 0000110b-0000-1000-8000-00805f9b34fb
[CHG] Device 88:C6:26:9C:F6:D4 UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
[CHG] Device 88:C6:26:9C:F6:D4 UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
[CHG] Device 88:C6:26:9C:F6:D4 UUIDs: 0000111e-0000-1000-8000-00805f9b34fb
[CHG] Device 88:C6:26:9C:F6:D4 UUIDs: 00001200-0000-1000-8000-00805f9b34fb
Pairing successful
[CHG] Device 88:C6:26:9C:F6:D4 Connected: yes [bluetooth]# agent on
Agent registered
Discovery started
Pairing successful
Connection successful
[NEW] Device BC:B1:F3:72:56:AB C3350
[NEW] Device BC:B1:F3:72:56:AB C3350 [bluetooth]# agent on
Agent registered
Discovery started
Pairing successful
No luck unfortunately! The “speaker connected” sound is played and no “speaker discconected” sound follows. I select as audio output “ALSA: OSMC streaming to Bluetooth speaker / headphones” but no audio is coming out of the (apparently connected) Bluetooth speaker, just out of the projector I have connected to the Pi 3 via HDMI.
Have you tried to connect from within MyOSMC instead of manually via bluetoothctl?
Initially I checked within MyOSMC to see whether it was connected. I just connected again via MyOSMC, seemingly with success, but audio is still only coming out of the projector via HDMI.
Try to reboot, generally if you choose “ALSA: OSMC streaming to Bluetooth speaker / headphones” and your speakers are connected then it should automatically only play to bluetooth and not HDMI
Rebooted, audio still outputting via HDMI only, despite speaker appearing to be connected:
[UE BOOM 2]# info 88:C6:26:9C:F6:D4
Name: UE BOOM 2
Alias: UE BOOM 2
Class: 0x240404
Icon: audio-card
Paired: yes
Trusted: yes
Blocked: no
Connected: yes
LegacyPairing: no
UUID: Vendor specific (00000000-deca-fade-deca-deafdecacaff)
UUID: Serial Port (00001101-0000-1000-8000-00805f9b34fb)
UUID: Audio Source (0000110a-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
Modalias: bluetooth:v000ApFFFFdFFFF
Device is a benq w1110.
Also tried rebooting without HDMI connected, and reconnecting to the speaker via bluetoothctl and using Yatse on android as a controller.
Could it be significant that I’m not seeing pulseaudio/a2dp as output options?
I finally got this working faultlessly. I have to follow a very specific order:
- If bluetooth speaker is currently connected but audio is only coming out via HDMI, then disconnect the speaker via shh/bluetoothctl
- In OSMC, go to Settings>System>Audio and choose analogue as sound output device.
- Restart OSMC
- Make bluetooth speaker discoverable
- ssh into OSMC
- at the OSMC command line, type ‘bluetoothctl’
- type ‘agent on’ and hit enter
- type ‘scan on’ and hit enter
- wait for the mac address of the speaker to appear
- type ‘trust [mac address]’
- type ‘pair [mac address]’
- bluetoothctl will at this stage say the speaker is paired and connected. then, a few seconds later, will say the speaker is not connected. ignore this.
- type ‘connect [mac address]’
- and the speaker connects! In OSMC, go to Settings>System>Audio and choose bluetooth as the output device.
This is using a UE Boom 2 and this → Bluetooth 4.0-Adapter, USB-A | Bluetooth | Notebook & Computer | 2direct which I got from German ebay. for 8 euros.
