the solutions for fstab seem quite kldugy… no? other scripts/timers etc…
just tried automount vis systemd, still doesn’t start the idmapd service… like I said looks like I need the nfs-client.target file that usually starts up all the dependant rpc services like idmapd.
To be honest I am lost in what are you trying to do! I assumed you just wanted to mount a NFS export on OSMC than all you need is a simple fstab entry and nothing more.
Or are you actually trying to run a NFS Server on OSMC?
I am trying to mount NFS 4 shares, fstab/automount/autofs all need idmapd to do proper id mapping between the server and clients.
I need the IDMAPD daemon to be running. I like automount/autofs because it mounts stuff on demand and unmounts them when not used vs fstab. This also deals with any issues like restart the nfs server nicely without stale file handles etc.
idmpad is service that is used by the nfs client to do idmapping.
that is what I have used forever really with good results.
You can use a system drop-in to override parts of a systemd unit, keep it persistent across updates and change ordering. It sounds like you want to add a Wants= directive.
Wants= directive means, there is a systemd unit that I can “want” but the problem is that there doesn’t seem to be, suspect this is more work than its worth, probably easier to put a sleep 20; restart nfs-common in the rc.local or rcS and be done with it…
Out of the box, the rpc.idmapd job fails to start with nfs-common.service but starts once nfs-common.service is manually restarted.
In fact, there is a “virtual” nfs-common.service file that is created on the fly by systemd from the init.d job.
-> Unit nfs-common.service:
Description: LSB: NFS support files common to client and server
Instance: n/a
Unit Load State: loaded
Unit Active State: active
Inactive Exit Timestamp: Thu 2017-09-21 10:34:06 BST
Active Enter Timestamp: Thu 2017-09-21 10:34:06 BST
Active Exit Timestamp: Thu 2017-09-21 10:34:06 BST
Inactive Enter Timestamp: Thu 2017-09-21 10:34:06 BST
GC Check Good: yes
Need Daemon Reload: no
Transient: no
Slice: system.slice
CGroup: /system.slice/nfs-common.service
CGroup realized: yes
CGroup mask: 0x10
CGroup members mask: 0x0
Fragment Path: /run/systemd/generator.late/nfs-common.service
Source Path: /etc/init.d/nfs-common
Condition Timestamp: Thu 2017-09-21 10:34:06 BST
Condition Result: yes
Wants: system.slice
WantedBy: sysinit.target
Conflicts: shutdown.target
Before: sysinit.target
Before: shutdown.target
After: rpcbind.target
After: time-sync.target
After: systemd-journald.socket
After: system.slice
References: sysinit.target
References: shutdown.target
References: rpcbind.target
References: time-sync.target
References: systemd-journald.socket
References: system.slice
ReferencedBy: sysinit.target
StopWhenUnneeded: no
RefuseManualStart: no
RefuseManualStop: no
DefaultDependencies: no
OnFailureJobMode: replace
IgnoreOnIsolate: no
IgnoreOnSnapshot: no
Service State: running
Result: success
Reload Result: success
PermissionsStartOnly: no
RootDirectoryStartOnly: no
RemainAfterExit: yes
GuessMainPID: no
Type: forking
Restart: no
NotifyAccess: none
KillMode: process
KillSignal: SIGTERM
SendSIGKILL: yes
SendSIGHUP: no
UMask: 0022
WorkingDirectory: /
RootDirectory: /
NonBlocking: no
PrivateTmp: no
PrivateNetwork: no
PrivateDevices: no
ProtectHome: no
ProtectSystem: no
IgnoreSIGPIPE: no
LimitNOFILE: 4096
StandardInput: null
StandardOutput: journal
StandardError: inherit
SyslogFacility: daemon
SyslogLevel: info
-> ExecStart:
Command Line: /etc/init.d/nfs-common start
PID: 611
Start Timestamp: Thu 2017-09-21 10:34:06 BST
Exit Code: exited
Exit Status: 0
-> ExecStop:
Command Line: /etc/init.d/nfs-common stop
PID: 603
Exit Code: exited
Exit Status: 0
SysVStartPriority: 14
So even though there is only a virtual nfs-common.service file, we can still use a “drop-in” to modify its behaviour, as Sam suggested.
I’ve only had time to try After=connman-wait-for-network.service and that was unsuccessful but there is sure to be something that will work. Unfortunately, I’m out of time for now.
Edit: After some more testing I’ve been unable to get drop-ins working with generated .service units. The problem seems to be that systemd applies the drop-in to the freshly-generated unit but a “systemctl daemon-reload” is required before the unit can be used. It was a useful learning exercise.
