I am following:
Installed the autofs package sucessfully.
Then output of “master” (added on the end /- /etc/auto.nfs.shares --timeout 15 browse):
sudo nano /etc/auto.master
#/net -hosts
# Include /etc/auto.master.d/*.autofs
# The included files must conform to the format of this file.
+dir:/etc/auto.master.d
# Include central master map if it can be found using
# nsswitch sources.
# Note that if there are entries for /net or /misc (as
# above) in the included master map any keys that are the
# same will not be seen as the first read key seen takes
# precedence.
+auto.master
Then the output of shares:
sudo nano /etc/auto.nfs.shares
/mnt/192.168.1.5/USB/USB1_d2/Nuotraukos 192.168.1.5:/Nuotraukos
Now myproblem is
If I go to
**osmc@osmc** : **~** $ ls -lah /mnt/192.168.1.5/USB/USB1_d2
total 8.0K
dr-xr-xr-x 3 root root 4.0K Feb 17 14:26 **.**
dr-xr-xr-x 3 root root 4.0K Feb 17 13:34 **..**
drwxr-xr-x 2 root root 0 Feb 17 14:26 **Nuotraukos**
But if I go
**osmc@osmc** : **~** $ ls -lah /mnt/192.168.1.5/USB/USB1_d2/Nuotraukos
ls: cannot open directory '/mnt/192.168.1.5/USB/USB1_d2/Nuotraukos': No such file or directory
**osmc@osmc** : **~** $ sudo systemctl stop autofs
**osmc@osmc** : **~** $ sudo automount -f -v -d
Starting automounter version 5.1.2, master map /etc/auto.master
using kernel protocol version 5.02
lookup_nss_read_master: reading master file /etc/auto.master
do_init: parse(sun): init gathered global options: (null)
lookup_read_master: lookup(file): read entry +dir:/etc/auto.master.d
lookup_nss_read_master: reading master dir /etc/auto.master.d
lookup(dir): dir map /etc/auto.master.d missing or not readable
lookup(file): failed to read included master map dir:/etc/auto.master.d
lookup_read_master: lookup(file): read entry +auto.master
lookup_nss_read_master: reading master files auto.master
lookup(file): failed to read included master map auto.master
lookup_read_master: lookup(file): read entry /-
master_do_mount: mounting /-
automount_path_to_fifo: fifo name /var/run/autofs.fifo--
lookup_nss_read_map: reading map file /etc/auto.nfs.shares
mounted direct on /mnt/192.168.1.5/USB/USB1_d2/Nuotraukos with timeout 15, freq 4 seconds
do_mount_autofs_direct: mounted trigger /mnt/192.168.1.5/USB/USB1_d2/Nuotraukos
st_ready: st_ready(): state = 0 path /-
st_expire: state 1 path /-
expire_proc: exp_proc = 4103074896 path /-
expire_cleanup: got thid 4103074896 path /- stat 0
expire_cleanup: sigchld: exp 4103074896 finished, switching from 2 to 1
st_ready: st_ready(): state = 2 path /-
