Hi All,
as the title suggests, I want to reset my VERO 4K to factory default.
I’ve follwed the guide here.
However, the VERO simply booted up normally. I then tried the troubleshooting guide, booting the device with the reset button pressed - now i get “waiting for root filesystem device” and then after a while “fatal error root filesystem device not found”
In the troubleshooting guide, it says I’m supposed to “rename the file ‘kernel.img’ to ‘recovery.img’”, only there is no such file on my USB Stick. If I use the OSMC installer to write the image, I can see the following files:
filesystem.tar.xz
imx6dl-vero.dtb
uEnv.txt
zImage
If I use Win32DiskImager, I can’t access the USB drive at all.
Any idea what I’m doing wrong here???
TIA,
Erik
You have downloaded the wrong image. You have downloaded the image for Vero 1.
Hi Sam,
oops - that would it explain it
Downloaded the right image, renamed the file and tried again - still no luck.
I can either boot up the machine with the “reset button” pressed, I then get a blue screen with “please stand by” no matter how long I keep button pressed, or without pressing the button, I then get the same mesage as in the first post…
I also had problems with that. I just did
rm -rf ~/.kodi
rm /walkthrough_completed
Plus any content you might have stored in ~/Movies, Pictures, TV Shows. That should be it, unless you added anything to fstab.
No luck with that either…
Sorry, that was a bit unclear…
Yes and no:
rm -rf ~/.kodi: OK, no error messages etc.
rm /walkthrough_completed: File not found
Please try using a micro-SD card.
Tried an SD card - worked like a charm! Thanks for the help and suggestions, guys - really appreciate it!
Glad to hear this.
Your USB stick might be duff.
