Thats what you have to do to enable browsing (but as you know what to connect to you don’t need browsing) and as the smbclient connected with smb3 I suggest to also set that in Kodi.
setting v3 on win and kodi worked and now I can see the media aka torrent_dump folder but all folders inside the media folder are empty. Is this just a permission issue or do I have to just delete folders and only have files in the media folder
Thanks for help and good night. My next step is to get autofs working because of better performance but doing baby steps.
Update: Folders are visible but empty and the .mkv files that are not in folders are not visible at all.
Do you mean in the “add source” step? During “add source” only folders will be shown.
Files will be either shown via the library or the “Files” menu after you added the source (normally you add the main folder)
Now I’m trying to add a whole drive the same way I did with my media folder yesterday and its giving me some issues. Should It work ? Do I have to pay attention to something specific ?
Sharename Type Comment
ADMIN$ Disk Remote Admin
C$ Disk Default share
D$ Disk Default share
F$ Disk Default share
G Disk
G$ Disk Default share
H$ Disk Default share
I$ Disk Default share
IPC$ IPC Remote IPC
Media Disk
print$ Disk Printer Drivers
Torrent_Dump Disk
one of the G drives is the one I dont know if the one $ or not
