I have a bluetooth remote that I’ve been using with my Vero4K almost a year now.
It has Vol+ and Vol- buttons that, unfortunately, are not directly re-learnable.
So I’m trying to modify my keymap file:
/home/osmc/.kodi/userdata/keymap/gen.xml
<keymap>
<global>
<keyboard>
<key id="61654">contextmenu</key>
<key id="61620">stop</key>
<key id="61572">pageup</key>
<key id="61573">pagedown</key>
<key id="61626">stepforward</key>
<key id="61627">stepback</key>
<key id="61637">fastforward</key>
<key id="61636">rewind</key>
<key id="61630">showsubtitles</key>
<key id="61675">osd</key>
<key id="61623">LIRC.Send(SEND_ONCE Yamaha_RAV337 KEY_MUTE)</key>
<key id="61625">LIRC.Send(SEND_ONCE Yamaha_RAV337 KEY_VOLUMEUP)</key>
<key id="61624">LIRC.Send(SEND_ONCE Yamaha_RAV337 KEY_VOLUMEDOWN)</key>
</keyboard>
</global>
</keymap>
…so that when kodi receives the key press, it will send the IR single to my AV Receiver to up/down the value.
I have modified the file: /etc/lirc/lircd.conf to include my Yamaha_RAV337 device:
begin remote
name Yamaha_RAV337
bits 16
flags SPACE_ENC|CONST_LENGTH|REVERSE
eps 30
aeps 100
header 8853 4532
one 533 1714
zero 533 589
ptrail 533
pre_data_bits 16
pre_data 0x857A
gap 107903
toggle_bit 0
begin codes
SYSTEM_POWER 0x000000000000E21D
KEY_VOLUMEUP 0x000000000000E51A # Was: VOL+
KEY_VOLUMEDOWN 0x000000000000E41B # Was: VOL-
KEY_MUTE 0x000000000000E31C # Was: MUTE
KEY_UP 0x0000000000006798 # Was: UP
KEY_DOWN 0x0000000000006699 # Was: DOWN
KEY_LEFT 0x000000000000AC53 # Was: LEFT
KEY_RIGHT 0x000000000000AD52 # Was: RIGHT
KEY_ENTER 0x00000000000055AA # Was: RETURN
ZONE2_SYSTEM_POWER 0x0000000000045BA
ZONE2_VOL+ 0x0000000000025DA
ZONE2_VOL- 0x0000000000024DB
ZONE2_MUTE 0x0000000000023DC
end codes
end remote
…rebooted, and turned on debugging.
I get the following in my kodi.out:
22:27:40.285 T:4078092880 DEBUG: -------------Keyboard keyevent---------------- 22:27:40.285 T:4078092880 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey with event type 0x0001, code 0x0073, value 0x0001 returned XBMCKey = 0x00af 22:27:40.285 T:4078092880 DEBUG: CLinuxInputDevice::KeyEvent: keyMods 0x0000 kbMods 0x0000 keyMapTable 0x0000 22:27:40.285 T:4078092880 DEBUG: CLinuxInputDevice::GetKeymapEntry table 0x0000 code 0x0073 value returned by KeyboardReadValue 0x011b 22:27:40.286 T:4078092880 DEBUG: CLinuxInputDevice::GetKeymapEntry values after KeyboardGetSymbol ktyp=0x00 kval=0x00 22:27:40.286 T:4078092880 DEBUG: Keyboard: scancode: 0x73, sym: 0x00af, unicode: 0x0000, modifier: 0x0 22:27:40.286 T:4078092880 DEBUG: OnKey: volume_up (0xf0b9) pressed, action is LIRC.Send(SEND_ONCE Yamaha_RAV337 KEY_VOLUMEUP)
But my receiver isn’t receiving a signal.
I tried a manual test via:
irsend -d /dev/lirc0 SEND_ONCE Yamaha_RAV337 KEY_VOLUMEUP
but I get errors:
irsend: could not connect to socket
irsend: Connection refused
Anyone have any ideas?
