Trying to use Microsoft MCE Remote with Leia
Hi.
Firstly, sorry because my ignorance but … which is the correct female jack to connect the IR receptor ? the external one or the one which is next to the ethernet port ?
And… Is there any way to enable and config the MCE Windows Remote in the Leia version (MyOsmc Still doesn’t work in testing Leia builds) ? (I’ve already added the keymap edito add-on)
Thanks.
You can use a mouse to focus the remote window (or copy the file to lirc.config). I will fix this for v18.
The 3.5mm port nearer the corner is the IR adapter connection.
It worked like a charm.
Thanks!
